9k All Day.
MY00 s2000.
Stupid Speedometer..
So, here's the deal..
Ive started noticing recently that my speedo will just stop working.... Ill be driving down the road then.....BAM. nothing. then maybe, if im lucky...it'll kick itself in again and start. if i launch...it wont move. but thats not the only problem... whenever it DOESNT work, or stop's, the second i let off of the gas, it sounds like its stumbling, and popping. (exhaust) sometime's even the o/d light will flash, and i got 2 codes today. P0500 P0502 (i think thats what they were) please help me bratha's.
MM's Samsquanch
1998 GT
![]() iTrader: 1 reviews
are you sure it was p0 and not p1500 & p1502?
because....P1500 Vehicle Speed Sensor Intermittent and..........P1502 Invalid or Missing Vehicle Speed Message or Brake Data or.. http://www.obd-codes.com/p0500 or... http://www.fordpower.net/forums/showthread.php?t=121824
MILITARY CREW
USMC E-4 Last edited by OneShotOneKill; May 27th, 2011 at 09:22 PM. |
1995 SVT Cobra
speedometer problem is probably the VSS (vehicle speed sensor) it plugs into the side of the transmission. Some use a gear installed onto the VSS which meshes with a gear on the mainshaft of the transmission.
The other version is magnetically driven but still plugs into the side of the transmission and has an electrical plug. Either one of these versions can fail and can be easily replaced with a used or new part. As for the check engine light and the 0500 and 0502 codes; both of these correspond to an issue with the vehicle speed sensor. Make sure its plugged in. If it is, replace it with a new one and that should take care of your check engine light and your speedometer issues.
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
#4 | |
9k All Day.
MY00 s2000.
9k All Day.
MY00 s2000.
but, would that cause the stumbling and bumbling that happpens whenever it stops working?
also, im just going to order both a new VSS and speedo gear. sound about right? |
Rollin' 18/ pushin' 2
The stumbling and popping shouldn't have anything to do with the vss. That sounds more like a clogged catalytic converter.
9k All Day.
MY00 s2000.
i dont have cats....
and it ONLY happens whenever the speedo stops.. |
1996 mustang gt
drive it faster lol
1996 gt new motor and hopefully more POWA 1988 5.0L lx sold |
MM's Samsquanch
1998 GT
Hmm weird, so is it like as soon as the speedo stops it seems as if fuel is getting cut off simultaneously?
MILITARY CREW
USMC E-4 |
1998 Mustang GT
sounds like maybe there's a short somewhere and the vss is going out with it maybe? I'd at least change the vss and start there, the gear should be in ok shape to re use but I wouldn't take any chances, they have a tenancy to fall apart when you remove them
9k All Day.
MY00 s2000.
yeah, as soon as the speedo stops it seems lie the car is stumbling.
kinda sucks since my car only has 51k on it..:[ and im not re-using the gear, im buying both a new one, and a vss. i mean, its only 50 bucks, so why not start there. and i dont really know if its fuel getting cut, but it kind of sound like the car doesnt know what it wants to do.
Does the entire cluster go out? Like the car just got shut off?
9k All Day.
MY00 s2000.
nope, everything is still there, everything minus speed.
no voltage jumping, nothing. you see my confusion on this matter then, aye? ![]() (btw, it isnt hard to get to, is it? |
Threads Similar to: Stupid Speedometer..
| Stupid people are stupid | 88TempoGLS | The Clubhouse | 34 | March 24th, 2012 04:55 PM |
| Speedometer fix | Wilhelm | 5.0 Mustangs | 9 | October 7th, 2010 07:16 PM |
| Stupid stupid people | Gerbig | The Clubhouse | 17 | July 16th, 2010 09:46 PM |
| stupid, stupid, stupid question re: wheels | ReverendDexter | 4V / SVT | 6 | December 18th, 2008 12:41 AM |
| Speedometer | Arhilion | 96-98 | 8 | May 23rd, 2007 07:36 AM |
