Transmission swap questions
Old May 30th, 2011, 07:56 PM   #1
yamanx's Avatar
1998 Mustang GT
yamanx is on a distinguished road
I have a 98' GT that has an auto in it and I am planning on putting the manual from my other 98' GT in the car. So the plus side to this whole thing is I have a complete donor car with all the parts I need to swap over but I want to clear up some question I have before I start to actually do the swap. I hear that you can keep the same brain from the auto car but just have it retuned to turn off the auto perimeters so that clears that up, but I hear some people of issues with the steering column, is there a difference between the two and do I need to swap? And also you have to trim some of the hole that is for the shifter, now I read this for the 99-04 cars so is this the same for the 96-98 body style as well? Will I be drilling a hole in the firewall for the clutch cable also?
Thanks for the help
Old May 30th, 2011, 10:09 PM   #2
mrblueoval is on a distinguished road
well my manual swap was in my 96 gt but I put a trans out of an 04 gt which is a t-3650. I purchased a manual puter from e-bay. I dont think you can swap out the computers as I did since in the model year 96 pats is in the dash but in 98 I believe it is in the coumputer so your ignition key chip is probably married to that computer. That being said you could get a tuner and then turn the auto trans function off so you can use your automatic computer I know my sniper tuner will do that. As far as the steering column I dont know of any reason you would have to mess with that. I did have to trim some of the tunnel but only about an inch across in the front. The hole is already there for the c-cable there is just a rubber plug there since your car came acrosss the assy line as an automatic there is even a little dimple for where you have to drill for the screw that holds the c-cable tro the firewall . Dont forget to swap out the little sub harness for the manual tranny its got about 5or 6 connectors on the end of it including plugs for the VSS,reverse lights, both rear o2 sensors.
Old May 30th, 2011, 10:55 PM   #3
yamanx's Avatar
1998 Mustang GT
Ya thats what I thought. I have the SCT Tuner from AmericanMuscle so I am sure I can tell them to turn off the auto stuff and they will shoot that tune out to me. Did you have any issues with the neutral safety switch?
Threads Similar to: Transmission swap questions
transmission questions? V8ornothing 96-98 1 April 26th, 2011 05:37 PM
Motor swap Transmission install Questions Slower Than You 99-04 6 April 22nd, 2011 06:22 PM
Dual Fuel Pump Questions and Auto Trans Swap Questions.. Mustang46 99-04 9 October 12th, 2010 12:19 PM
PI Head Swap and Transmission Swap jEEd 96-98 18 May 14th, 2009 12:57 AM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 06:48 PM
