Goin to a U-pull yard today, i need some tips for looking for GOOD parts..
Old June 1st, 2011, 08:36 AM   #1
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
1st queston-i have the setup in the pics below,its all PI..I also have a 1997 4.6 thats in my cougar.I plan on putting thsese heads and cams in when i get the help but rite now im gathering parts.It seems ive gotten a bunch of missinformation so thats a big reason im here.What else will i need for the swap? i Already have the PI manifold swap on my car so i have all that stuff.Do i need the timing chain cover and vavle cover? Mine is a 97'....
2nd queston- i have read in a few places that the 5.4 trottlebody is larger than the 4.6, if this is true what year and moddel 5.4 should i look for, i have a 1997 4.6 with the stock pleunum and Tbody and while im at the Upull id like to upgrade one or the other..
Old June 1st, 2011, 05:31 PM   #2
1998 Mustang GT
MustGT98allday will become famous soon enough
1st. You dont need a new timing cover or valve covers unless you have windsor heads. Count your valve cover bolt holes in your heads and make sure its 11. If its 13 then you need different valve covers. also if its 13 then you will need timing cover i think (dont quote me)
2nd. as far as i know the 5.4 plenum faces the other way than the 4.6 so dont think it will work. (again dont quote me I just havent seen a 5.4 going to the left)
pi swapped and dropped sn95
Old June 1st, 2011, 07:24 PM   #3
97 GT
97autumnGT is on a distinguished road
the 5.4l throttle body will work if you can grid and weld a little also a crown vic plenum is a half inch taller than your stock mustang one. I've got both on mine.
Old June 1st, 2011, 07:26 PM   #4
TooFast4theFUZZ
the throttlebody can be flipped and work just fine, its the size that im worried about.Maby ille just find and measure one while im there.And yes,my heads that i have are romeo and my car was assembled in aug. 1997 the last full month of production for it..i guess ille go out there and count.Thats a good idea, thanks.
Old June 1st, 2011, 07:34 PM   #5
TooFast4theFUZZ
clearence idnt an issue with me, i even had on a 70mm setup witrh spacers and all, wouldnt fit under the stock hood but i have a 3in cowl.. heres the pic of my engine.So ur saying thet that goofy tubular shapoed plenum on alot of vics 's is actually better than the square one i have with the 4.6ohc on it? if so ima grab one asap..
Old June 3rd, 2011, 05:38 PM   #6
TooFast4theFUZZ
well i pulled the diffrent plenum anyways and painted it up, so if anyone needs the stock plenum that says 4.6 on it pay the shipping and its yours,alo have pi heads and cams that were never dissasembled also that im not going to use..when my count get up ille throw them up for sale.
Old June 3rd, 2011, 06:57 PM   #7
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
This should help you get them up: http://www.moddedmustangs.com/forums...hread-100.html It is the only place on the forum you can just post whatever to get your count up.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old June 4th, 2011, 01:05 AM   #8
TooFast4theFUZZ
lol ille get there leggit.Just may take awhile...
Old June 4th, 2011, 11:13 AM   #9
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Good man. Reps to you for that.
MODS IN GARAGE
NCMM ORIGINAL
Old June 4th, 2011, 01:00 PM   #10
JasinEdward is on a distinguished road
what are you looking to get out of the extra pi heads you have?
Old June 4th, 2011, 03:02 PM   #11
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
A PM will work alot quicker and also help keep the tech threads clean.
MODS IN GARAGE
NCMM ORIGINAL
Old June 4th, 2011, 04:58 PM   #12
TooFast4theFUZZ
PM sent..
Old June 4th, 2011, 05:07 PM   #13
TooFast4theFUZZ
BTW, the plenum gave my eng a better growl and it seems it has better throttle response just a bit but it rides the RPM's higher when i full out gun it befor it engage, i can give the tires a nice squak when i gun it doing 30, even with the overdrive on..hehe so the setup helped..
Threads Similar to: Goin to a U-pull yard today, i need some tips for looking for GOOD parts..
goin to the u pull it.... JasinEdward 96-98 6 May 27th, 2011 01:19 AM
Goin to vegas tomorrow, tips? Ideas? Stds? 93hatch The Clubhouse 24 April 17th, 2011 01:17 AM
No more junk yard parts!!!!!!! 93mustank 5.0 Mustangs 29 December 29th, 2008 03:20 PM
Took the coupe to the scrap yard today! ujslost The Clubhouse 29 July 27th, 2008 07:16 PM
junk yard performance parts fakesaleen General Tech 7 March 23rd, 2006 07:53 AM
