Hanging rpms after sct tune
LinkBack (1) Thread Tools
Old June 2nd, 2011, 11:02 AM   1 links from elsewhere to this Post. Click to view. #1
Ruffellbaker's Avatar
1997 Mustang GT
Ruffellbaker is on a distinguished road
Ive had my tuner for around 2 months now. At first I was told that I was having the problem because I had a JET maf calibrated for my injectors. So I put the stock Maf back on and had Bama send me a tune to adjust for the injectors and stock Maf. But my rpms still hang horribly when the car is tuned and I never had a problem with them hanging stock. I read today about the IAC gasket trick and Im thinking about trying it. Has anyone else had this problem after the Tune? Its becoming very frustrating that I paid almost $400 for the tuner and cant even use it.
PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune.
Old June 2nd, 2011, 11:59 AM   #2
1996 mustang GT
projectGT is on a distinguished road
The same thing happens to me too when I put it on neutral, buy only for a few seconds.
Old June 2nd, 2011, 12:13 PM   #3
zigbigadoru's Avatar
97 Mustang GT
slower than the speed of smell
zigbigadoru will become famous soon enoughzigbigadoru will become famous soon enough
could be your iac or tps sensor. check those out
Originally Posted by XTCNAGT View Post
That's what you get for excercising.
You think my lungs and chest hurt when I drive down the road for a triple baconator? No. You know why? Cause I'm smart.
Time for a nap.
Old June 2nd, 2011, 12:27 PM   #4
1997 Mustang GT
It only does it with the tune tho. Stock it runs fine
Old June 2nd, 2011, 01:08 PM   #5
1998 mustang power's Avatar
1998 Mustang GT
1998 mustang power is on a distinguished road
mine does it to i did the copper cap mod and its fine now
1998 coupe 4.6L Cold air intake
Pypes o/r x pipe
Flowmaster super 44 mufflers
Sct programer
Old June 2nd, 2011, 01:50 PM   #6
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
sounds exactly like a tps, since having my handheld tuner and mods my car ruins the TPS once a year..i blame full throttle for that.But it never fully goes out,it does exactly like you said and pay attention to when you GUN it, your gears will probly change at a bit diffrent RPM's if its an auto.Is some how the tune throwing extra voltage at your TPS.?
Old June 2nd, 2011, 02:42 PM   #7
Pony Boy
blakenel1122's Avatar
9.84@148
blakenel1122 is an unknown quantity at this point
I had the same problem with my car, and I did the Beer can mod. Now the rpms dont hang! But you want to make the hole the size of a hole puncher for the new "gasket". But also when I did this, The car idles at like 600-650 when its cold but when it warms up, its at like 850-900.
-Flowmaster Force II Catback
-BBK CAI
Old June 3rd, 2011, 10:02 AM   #8
1997 Mustang GT
Thats what I needed to hear. Thank you
Old June 3rd, 2011, 11:17 AM   #9
Pony Boy
9.84@148
No problem, I hope this will help you solve your issue
-BBK CAI
Old June 5th, 2011, 12:02 AM   #10
1997 Mustang GT
I went ahead and just ordered one of the premade ones from ebay just because I work 40+ hours a week and I have classes at college ontop of that and dont have time to make one. But hopefully it fixes my problem. When Im running on the stock tune the car runs fine. But on my sct tune is when the rpms hang. is that what happened with you?
Old June 6th, 2011, 08:00 AM   #11
Pony Boy
9.84@148
I have heard of people doing that but one of the most important things is the hole size. And Ill try to find the link later on today that shows what the different hole sizes do.
-BBK CAI
Old June 6th, 2011, 09:26 AM   #12
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
If the problem only arises with the Bama tune, and goes away when you return it to the stock tune, then it's obviously an issue in the tune file and should be corrected by your tuner.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old June 6th, 2011, 11:36 AM   #13
1997 Mustang GT
Car is finally tuned and running after 3 different tunes. Rpms still hang a little but nothing major. Its just a little bit more than stock, so Ill still use the IAC plate and see what happens. Blakenel1122 if you could still find me the link to the different hole diameters it would be great.
Old June 6th, 2011, 02:11 PM   #14
Pony Boy
9.84@148
Been playing with IAC restrictor diameters
There you go!
-BBK CAI
Old June 13th, 2011, 07:00 PM   #15
1997 Mustang GT
Welp. I did the restrictor plate with a 1/4 inch hole. Made very little or no difference. I even got new injectors to see if that was the problem. Ive been calling the tuners at BAMA trying to get it fixed but they cant figure it out either. Any ideas?
Old June 13th, 2011, 07:38 PM   #16
1997 Mustang GT
Also, my car idles higher now. It idles right around 1,000rpm maybe 900 when fully warm. I checked the voltage at the tps sensor and I got 1.2v which is double what it should be at idle. Although it is idling higher so that would probly cause the tps to show more voltage.
Old June 14th, 2011, 10:51 AM   #17
Pony Boy
9.84@148
Are these readings coming from your car with the pre-made one from ebay?
-BBK CAI
Old June 14th, 2011, 05:20 PM   #18
1997 Mustang GT
no this is with the copper cap with the 1/4 inch hole.
Old June 15th, 2011, 05:38 PM   #19
TooFast4theFUZZ
just go buy all new sensors..install them and se if it works. if not just go return them and eliminate them from your list of possible problems..but it sounds like a tune problem.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/220933-hanging-rpms-after-sct-tune.html
Thread RPMS taking forever to come back down after SCT tune? | Forums at Modded Mustangs | BoardReader This thread Refback June 28th, 2011 04:03 PM
Threads Similar to: Hanging rpms after sct tune
RPMS taking forever to come back down after SCT tune? Ruffellbaker General Tech 1 April 22nd, 2011 05:53 PM
rpms started hanging in last couple of days... BakerFX4 99-04 11 August 22nd, 2009 06:50 PM
Hanging rev flattusmaximus78 5.0 Mustangs 27 December 22nd, 2008 01:11 PM
Hanging rpms dothedew1654 5.0 Mustangs 4 August 29th, 2008 11:06 PM
rpms hanging dothedew1654 5.0 Mustangs 10 March 27th, 2008 01:18 AM
