slight shake at idle
Old June 2nd, 2011, 09:53 PM   #1
mrblueoval is on a distinguished road
My stang has a slight shake at idle. Car has recently been tuned up with quality wires , belden brand from napa. All of the plugs I replaced looked good. The coils ohmed out good. So what else. Could cause a slight rough idle ? The IAC is new (motorcraft). Motor is a Pi motor from a 2002 GT it has approx 76K. On it.
Old June 2nd, 2011, 10:39 PM   #2
GMoney98's Avatar
1998 Mustang GT
13.22@106.42
GMoney98 is on a distinguished road
its called v8 power nothn to worry bout unless its doin it real bad
PI Heads & Intake\ Hitech Stage 2 Cams\ Borla Cat-Back\ O/R X pipe\ BBK Shorties\ 3.73 Gears\ BBK CIA\ BBK 78mm TB&P\ BBK U/P\ B&M Shifter\ Diablo tuned\ Eibach springs\ Tokico D-spec adj\ CC plates\ Eibach F/R sway bars\ Sub-F cn\ 290rw ponys
Old June 4th, 2011, 05:06 PM   #3
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
perfect answer..i thought mine had problems also untill i realized its the extra HP i added to the engine plus the 8 not honda style 4....
Old June 5th, 2011, 09:02 PM   #4
tfofkyle's Avatar
02 Mustang GT
tfofkyle will become famous soon enoughtfofkyle will become famous soon enough
new motor mounts should take care of any shake you might be having.
Threads Similar to: slight shake at idle
Front end shake LXpat93 2.3 Mustangs 9 February 11th, 2012 11:36 AM
shifter shake 94mustang94 5.0 Mustangs 28 May 27th, 2011 01:28 AM
slight idle problem and feels like a lack of power nysiv16 V6 Mustangs 34 December 1st, 2010 08:50 AM
shake terribleonexx88 5.0 Mustangs 7 March 29th, 2008 11:13 PM
slight engine shake? jasons_98gt 96-98 3 January 19th, 2008 11:10 AM
