Which Clutch?
Old June 5th, 2011, 11:49 PM   #1
Ruffellbaker's Avatar
1997 Mustang GT
Ruffellbaker is on a distinguished road
Which Clutch?
Its about time for a new clutch, one of my bearings is chirping and the clutch chatters a little sometimes. When I bought my car the guy told me that it is not the stock clutch. Im not sure what brand or what stage it is. Im guessing stage 2 because its stiff but perfect for daily driving too. Are there any brands you guys prefer? I work at Advance Auto so I could get a discount on Zoom clutches but I doubt they are any good.
PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune.
Old June 6th, 2011, 04:10 PM   #2
robb15033's Avatar
1997 Mustang 3.8
robb15033 is on a distinguished road
I really like my SPEC clutch and flywheel. Others that you can look into are RAM, McLeod, Fidanza, and Centerforce. I have seen Zoom clutches for sale for Mustangs but never have known anyone to install one personally. Just check into getting a FRPP throw out bearing along with a new pilot bearing when its time to do it. Its a really nice feeling having a good clutch to work with!
'97 3.8 MODIFIED
Old June 6th, 2011, 06:21 PM   #3
98BAGT is on a distinguished road
i have a spec clutch stage two but im yet to install it. if you wait 2 weeks ill let you know how i like it
Old June 6th, 2011, 10:55 PM   #4
1997 Mustang GT
Yea let me know. My clutch grabs fine its just either the pilot bearing or the throwout bearing is squeaking whenever my foot is off the clutch. Hopefully not a big deal until I get the money and time to put a new one in.
Old June 7th, 2011, 12:06 AM   #5
MikeHP350's Avatar
1998 Mustang GT Conv.
MikeHP350 will become famous soon enough
Send a message via AIM to MikeHP350
The RAM HDX is on sale right now at americanmuscle.com. I have one and I love it, its pretty grippy and I havent had any problems with it . +1 on going with the FRPP throwout and pilot bearing.
CAI, 75mm TB/Upper intake Plenum, Shorty Headers, Catted H-pipe, Flowmaster 40's, STEEDA U/D Pulleys, Sniper SF 93 Oct. Tune. MSD Coils/8mm Wires, NGK Iridium plugs, Full PI swap H/C/I, STEEDA adj. clutch cable/quadrant, RAM HDX Clutch.
Old June 7th, 2011, 06:54 AM   #6
Uberstang1's Avatar
1997 Mustang GT
Uberstang1 is on a distinguished road
I personally run a spec stage 2 plus, but if you do some research it seems spec has one of the highest failure rate of the aftermarket clutches.I would recommend a Mcleoud or a Centerforce.
97 GT, 4v swap,procharged,longtubes,tubular front suspension, team z rear suspension,4.10s moser 31s, to much to list.
Old June 7th, 2011, 09:45 AM   #7
All Motor 1998 GT
cstreu1026 will become famous soon enough
More than likely it is the TOB squeaking. Before spending money on a new clutch I would just inspect the one you have and if you need a new one don't go over board. With your current mods there really isn't a reason to use much more than a good stock replacement.
Old June 7th, 2011, 10:33 AM   #8
1997 Mustang GT
Well the clutch I have now was on when I bought the car and I love it. I think I might just keep the same clutch since it still grabs nice and replace the bearings and possibly get a new flywheel or at least get mine resurfaced. How do I go about replacing the pilot bearing? I saw somewhere to use a slide hammer but I wouldnt feel comfortable using that on my crank.
Old June 7th, 2011, 10:44 AM   #9
All Motor 1998 GT
the pilot bearings are real PITA. I am heard of people packing them full of grease to help force them out.
Old June 7th, 2011, 08:24 PM   #10
MM's Samsquanch
OneShotOneKill's Avatar
1998 GT
OneShotOneKill will become famous soon enough
just get a bearing puller from autozone, just replaced mine last week, used a blind hole puller and slide hammer.
bitch was in there so tight it came out in two pieces
MILITARY CREW
USMC
E-4
Old June 8th, 2011, 06:55 AM   #11
Uberstang1's Avatar
1997 Mustang GT
Yea I had to pounc out the inner bearing race with a chisel in hammer just to fit the pilot bearing puller inside, the grease trick def didn't work for me.
Old June 8th, 2011, 09:29 AM   #12
1997 Mustang GT
Ive been doing some reading and Im pretty sure its the TOB. Thinking about going with the Ford Racing TOB. Is it a direct fit? I saw one review where the guy had to make a ton of adjustments.
Threads Similar to: Which Clutch?
clutch pedal vibration and excessive clutch chatter mscribellito 99-04 13 August 19th, 2010 04:59 PM
Clutch noise? New clutch install mtbr101 99-04 0 December 8th, 2009 10:08 PM
clutch replacement- replace whole clutch assembly or just clutch disc? WilltheThrill 4V / SVT 12 December 13th, 2008 12:18 AM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 10:08 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 02:33 PM
