1996 mustang gt
15.71@91
How to improve 1/4 mile time?
I have taken my 1996 mustang gt to the strip twice. Once when it was rather hot out and once when it was around 60 degrees. When it was hot out the best i ran was a 15.9 and when it was cooler i ran a 15.7, but both of these times are way slower than what i should be getting. Is there any tips on how to control the tire spin when first launching on the track?
need tuned
![]() iTrader: 1 reviews
Get some sticky tires !! I run Nitto 555 Drag Raidial
1 of 829 made Bright Tangerine Orange 10Lb Vortech V2,CXRacing FMIC MHS Stage 2 Blower cams,39# Injectors PI Intake,Ported and Polished NPI Heads BBK Headers,78mm BBK Throttle Body Mac H Pipe,2.5 inch Flowmaster Exhaust ,373 Gears |
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
why do you say it should be faster? what all mods are done to it.? if its pretty much stock with just a few bolton it makes sense where your at with your times..You may get better throttle response and all with some upgrades but they wont shed anytime off your 0-60 or 1/4 mile...best bet is to start buying PI swap parts..
1997 Mustang GT Conv.
14.7@92
Get 4.10's and sticky tires. I did that and I went from a 15.2 to a 14.7. I also got subframe connectors that helped out a lot too.
1998 Mustang GT
![]() iTrader: 2 reviews
thats not really alot of money or work especially if he did the work himself. Thats not even close to what i spent in money and hours when i did my pi swap for some little horsepower upgrade. and in 1/4 mile a half a second is alot. alot of people scream horray over .2 seconds
hey tatertot99. How much of an improvement (not time wise but handling) did the sbc do. I just got my maximum motorsports flsfc in and cant wait to install
pi swapped and dropped sn95 |
re gearing an axle is a lot of work because and can be easily messed up and have to be done over and by jumping to 4.10 you lose ALOT of gas mileage.
1997 Mustang GT
For one if you are still running the stock 3.27s rear gear thats gonna kill you every time, the first mod to be done on a 94-04 mustang is gears, either 4.10s or 4.30s in my opinion. When it comes down to cutting a good 60 foot your looking at suspension and tires, and obvioulsy a good set of springs and shocks/struts to compliment the setup. I would get a good drag radial and a good rear suspension setup. When choosing a 4 link keep in mind that your going to expereince increased NVH with almost all suspension mods. Stay away from control arms that have a poly ends on both sides, they will cause suspension bind and added stress to the weak factory torque boxes. I would recommend a good lower control arm with at least one spherical end which will improve traction greatly and also allow the axle to still have some articulation. As far as uppers I would pick up a good set of adjustables to you can set an optimum pinion angle which will also greatly improve your 60 foot for the track. If you wanna go all out I would recommend my setup all day long, Team Z double adjustable lowers with a spherical end on the torque box side with a solid steel collar on the axle side, and the team z relocated upper kit which relocates the uppers for an optimal instant center and they are also double adjustable with spherical ends on both sides, if you opt with an all solid end setup like this you can adjust your pinion angle to -2 degrees and get ready to rip up the track.
97 GT, 4v swap,procharged,longtubes,tubular front suspension, team z rear suspension,4.10s moser 31s, to much to list.
1997 Mustang GT
As far as gas mileage goes, I'm currently running a 4.10 rear gear on on centrifically supercharged 4v making 420rwhp and honestly the decrease in gas mileage isn't that bad at all. Do not fear the gear.
i planned on going to a 3.73 and i currently have 2.73. and i know the gasmileage will deacrease a lot for the highway because i did it in my jeep went from 3.73 to 4.10 and lost 5 mpg highway. city stayed the same because you just shift into a higher gear but when your already in 5th gear you dont have another gear so your only choice is to cruise at 70mph turning 3k RPM.
#11 | |
1997 Mustang GT
#12 | |
TooFast4theFUZZ
#13 | |
1997 Mustang GT
1996 mustang gt
15.71@91
The previous owner put the exhaust on and some add-ons but i was only 16 at the time and knew nothing about cars lol. I think im gonna give him a call and find out what he all did to it. Im sure it still has the stock gears and i was thinking about addingg some 3.73 gears, but im only getting 20 mpg as is...and my mpg has been decreasing for some reason over the past year from 25 to 20. I have no idea what the reason is for that. My time varied from 15.9 on a hot day, to 15.7 on a cooler day, and it isn't consistent at all which frustrates me. The previous owner told me that it should be doing around 14.9 but also im 6'7 and weigh 300 lbs...so im sure that plays a roll in it. thanks for all the input tho!
1996 mustang gt
15.71@91
and also, i found a CAI that adds 10 hp but i hear they are a waste of money...and i was wondering if a short throw does help or not. I'm still learning and i dont know a lot but i know enough.
Hooo Ha Ha
im still running 3.08s lolz
![]() 410rwhp 520rwtq @ 12.9 psi |
Rollin' 18/ pushin' 2
![]() I can probably get my old 3.55's back from my cousin if you want them man. I don't think she is going to use them.
Hooo Ha Ha
I might take you up on that. I really would love me some 3.55s
#19 | |
![]() When (if ever) were the O2's last replaced? It sounds like it's about time to change them.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
1996 mustang gt
15.71@91
Threads Similar to: How to improve 1/4 mile time?
| What can I do to improve my time? | Codeman | Drag | 17 | June 23rd, 2011 10:37 PM |
| First Time at the 1/8 mile | YellowRider0905 | Drag | 6 | April 22nd, 2011 09:48 AM |
| new best 1/4 mile time | UrbanRedneck | 2005 - 2010 | 26 | October 23rd, 2009 02:43 PM |
| What would my 1/4 mile time | SLayer7391 | 2005 - 2010 | 10 | July 1st, 2008 10:57 PM |
| My 1/4 mile time | pfcbrook | 99-04 | 16 | February 24th, 2008 04:16 PM |
