PI intake swap Coolant Temp question
Old June 7th, 2011, 10:52 AM   #1
Ruffellbaker's Avatar
1997 Mustang GT
Ruffellbaker is on a distinguished road
Instead of taping the intake or housing to put the sensor in, couldnt I just cut the sensor off and splice the wires in with the ones to the other sensor? Just seems like a cleaner simpler way to me.
PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune.
Old June 7th, 2011, 11:53 AM   #2
jasons_98gt's Avatar
1998 mustang GT
jasons_98gt is on a distinguished road
Send a message via Yahoo to jasons_98gt
not sure if you can do that or not.
im swapping my motor with one from a lincoln and the tempature sensor is threaded into the cylinder head under the intake manifold.
i looked on my heads from my mustang engine theres a spot for it sure enough.
drivers side head. right in the front.
Old June 7th, 2011, 02:33 PM   #3
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
No because the sensors use different ranges
The passenger side on is the one that the ECU runs off of. The driver side runs the gauge.
410rwhp 520rwtq @ 12.9 psi
Old June 7th, 2011, 09:57 PM   #4
1998 Mustang GT
MustGT98allday will become famous soon enough
my temp gauge doesnt work so when i did my pi swap i just put the ecu sensor in the hole in the intake and left out the one for the gauge
so yes...i never know how hot my engine runs
i couldnt get the right tap for it and i didnt wanna wait to send it out to get done so with my gauge not working i took a short cut.
pi swapped and dropped sn95
Old June 8th, 2011, 01:19 AM   #5
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
You can do what i did.
I have a metal tube in my upper radiator hose. I tapped an aftermarket coolant gauge into it and run it like that.
Atleast i know the temperature when the thermostats open
Old June 8th, 2011, 12:20 PM   #6
1998 Mustang GT
13.046@107.49
cruizer will become famous soon enough
It really sounds like you are referring to the knock sensors and not the coolant temp sensors. The knock sensors we can't use with a GT computer and the coolant sensors are in the coolant crossover in front of the alternator.
here is a pic of the knock sensors. There are two of them. In the block valley near the middle on both sides of the heater tube
98 Mustang GT 13.795 @ 98.87 N/A
Main mods: PI Swap, 3.73 gears, E85
My Mark VIII and T56 swap
Threads Similar to: PI intake swap Coolant Temp question
Coolant sensor not coming up to temp sniperd 5.0 Mustangs 5 January 25th, 2011 06:21 AM
Avg. water temp for s/c coolant? Slo Poke 2005 - 2010 5 October 29th, 2010 04:57 AM
coolant temp guage problems aekrot 2005 - 2010 0 March 20th, 2010 06:33 PM
Coolant TEmp Sensor question nHuman 96-98 2 August 19th, 2008 04:08 PM
coolant temp sensor question nHuman 99-04 3 August 18th, 2008 02:30 PM
