which swap
View Poll Results: swap in a mark viii 32v motor in my 97 gt or do pi swap?
pi swap 8 100.00%
mark viii 0 0%
Voters: 8. You may not vote on this poll
Old May 11th, 2007, 11:08 AM   #1
97_stang_gt is on a distinguished road
which swap
should i swap a mark viii or do a pi swap on my 97 gt
Old May 11th, 2007, 03:42 PM   #2
Proud American
MustangMatt96GT's Avatar
PI swap will be much easier and less expensive! But keep you NPI heads and just take them off and get somebody to Port and Polish them and get some Stage 2 cams and new valve springs!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old May 11th, 2007, 03:48 PM   #3
Boomer is on a distinguished road
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
I voted P.I., let me explain why. The mark VIII has B heads which are by far the worst of all the modular family and will lack power unless you throw large amounts of boost at them. The P.I heads are going to give you a little more due to the compression bump, combined with the P.I. cams and intake it will smoke the car with the stock markVIII. The 2 valve is going to make more torque and horsepower without even getting into the bolt ons.
If you are going to do a 4 valve swap at least find a set of 99+ heads and intake. The mark VIII shortblock would be even better with the 2 valve heads however you'll be at the point where you may have to high of compression to run pump gas without a tune.
Budget build, Mark VIII shortblock, P.I cams,heads and intake with all the bolts could easily net 300 rwhp. This is not something I would suggest for a daily driver. Pick up a set of used comp cams and some mild porting on the heads you'll see even more.
My opinion only, I'm sure many will vary.
Old May 11th, 2007, 03:51 PM   #4
Proud American
Yeah he doesnt want to do the heads! It was in his other post! But why would you put 2V heads on a 4V motor?
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old May 11th, 2007, 04:46 PM   #5
2.98 cc piston (MarkIII) with a P.I head would net around 11.5:1 compression. This next motor I am building is a junkyard special, 96 cobra pistons, gt crank and NPI heads ported by yours truley . I am trying to find a decent rod that will hold up to the high rpm range I plan to spin. I think th only part I will spend the extra $$$$ on will be the rods. I will either modify a realy ford aluminum NPI into a carbed intake or buy the edelbrock when and if I ever see results from one. Again most of this stuff is spare parts I have lying around, my intentions are to do a big bore with a similar set up. I will have " the fastest N/A NPI headed Mustang" one way or another.. lol
If my back heals in enough time I'll be able to finish my car, right now I am only doing piece work for people to pick up some extra cash here and there. Yesterday marks one full year since I hurt my back, I have been fortunate to be able to hang out at a performance shop and research every knook and cranny of what it takes to make real power. I had to sell out of the last car I was partial owner on and never even got any wheel time. Enough with the life story lol
There is plenty of information out there that shows there is alot more power potential to be made with any Modular engine. It is taking the time,research and money to put it all together and make it work as a combo. Ya get what I'm saying ?
Old May 11th, 2007, 11:30 PM   #6
1998 GTvert
noppe180 is on a distinguished road
Send a message via AIM to noppe180
u gonna do this urself?!?!?!? rofl better be good do a pi swap cams for npi heads and a kenne bell ur be off the hook
Old May 12th, 2007, 12:44 AM   #7
Keep reading your magazine articles about how great P.I. heads are. LOL
"better be good do a pi swap cams for npi heads and a kenne bell ur be off the hook" ..
What language is this? Am I the only one that has no clue what this means ?
Anyhow I'm sure that this post had no mention of a blower, it was about a swap if I read right. If your use of words in a broken sentence that makes 0 sense is a sign of your intelligence I would hate to see the work you perform on your car.
Threads Similar to: which swap
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 04:33 PM
PI Head Swap and Transmission Swap jEEd 96-98 18 May 14th, 2009 12:57 AM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 06:48 PM
3.8 swap to 5.0 goldhorse V6 Mustangs 1 August 10th, 2007 12:57 AM
351 Swap Cskit1500 5.0 Mustangs 6 November 16th, 2006 07:40 PM
