rear end question....
Old June 13th, 2011, 11:11 PM   #1
JasinEdward is on a distinguished road
Is there a stock rear end say from an explorer with a 3.73 that will bolt up to my 96 gt?
Old June 14th, 2011, 02:20 PM   #2
wrenchhog44's Avatar
1998 Mustang GT
wrenchhog44 is on a distinguished road
Not that I am aware, no. I believe most explorers had a leaf spring rear end instead of the coil spring rear end. But if the lug pattern, axle width, brake lines, axle mounting system, are identicle, I don't see why not.
When in doubt, go by the rule of dog...
If you can't eat it or f*ck it, just piss on it and walk away.
Old June 14th, 2011, 06:07 PM   #3
Ethan79's Avatar
1994 Mustang GT
Ethan79 is on a distinguished road
I have an axle out of an explorer in my Jeep Wrangler. That being said you can make them work in anything. But you have to get the brackets that work for your vehicle. Correct me if im wrong but i think that explorers have Leafs in the rear which means youd need to get spring perches and control arm brackets for the stang. not worth it. Regear your 8.8 if the 3.73s were all you were looking for.
1998 Mustang GT- SOLD
2000 Jeep Wrangler 4" lift, Locker, Ford 8.8 and a shit ton of other junk- SOLD
1994 Mustang GT-306, E303.....
Old June 14th, 2011, 09:29 PM   #4
98BAGT is on a distinguished road
explorers had leaf springs and where 31 spline where as the mustang rears are 28 spline. i have a ford 8.8 with 4.10's in my jeep. but as far as putting it in the mustang it cant be done because the housings are actually different.
Threads Similar to: rear end question....
rear end question mutlyi4 5.0 Mustangs 2 October 20th, 2010 11:29 PM
rear end question. motorhead6776 V6 Mustangs 3 May 1st, 2010 02:36 PM
Rear end question 98stangv6 The Clubhouse 6 July 27th, 2009 08:55 PM
rear end question busaonboost 96-98 4 June 10th, 2009 02:55 AM
rear end question.... 7-up man 5.0 Mustangs 27 September 22nd, 2007 11:49 PM
