LinkBack (3) | Thread Tools |
#1
On3 Performance Turbo Kit Install
Well, after being a die hard N/A kinda guy all these years, I have decided to take a step into the turbocharged world.
My current car is a 1998 Cobra, with a 2003 Mach 1 Longblock. I put 96-98 Cobra Intake cams in it, and with bolt-ons it was making 346rwhp, and good enough for 11.6's@118 on Drag Radials with a 1.6 sixty foot. This car is basically a full bolt-on car, with some suspension and the other "goodies" that push it more towards the "drag car" type. I will try and keep this thread updated as much as possible with pictures, my opinion on the kit, dyno results, track results....etc. My goal is basically to run 8 PSI, run 10's with ease, and not destroy the T45 I am currently running. If you have any questions, please feel free to ask. Changes:
Initial Impressions I got the kit a few days after ordering, and everything was there except a few fittings for the turbo/oil lines....and a fitting for the oil filter relocation. I was told that I would have them in a few days after I received the other parts....and that I did. I was contacted to ensure I received them as well. I have had a few questions here and there about some stuff....and Chad and Mike have been very helpful along the way. They also gave me some recommendations on the install, which I appreciate very much. Customer service up to this point, A+ The kit......... This kit, when in your hand is very nice looking. I am a VERY picky person, as the On3 gang can probably agree.... There are a few small things I see with this kit, which I feel I could probably upgrade, or "touch" up....but I don't really want to. I want to put the kit on, as it comes....and see what type of gains I get both on the dyno, the track...and the street. I will be honest, I was very impressed initially.....by the quality of the components....but I know "time will tell" the truth. I am pretty confident I will not have any negative issues with this kit. I did NOT buy this kit to daily drive, nor to put 20,000+ miles on. I bought this kit to put on a car that sees 2,000 miles every 2 years, and stays in my garage 365 nights of the year. If this kit performs to my expectations, I will be very pleased. And do not think for ONE MINUTE, that is there are small issues/hang ups along the way that I will complain.....as I realize I saved thousands by going this route. If I need to make a cut here, a weld there....or even re-do all the connections....I honestly do not care. The kit came just about exactly as pictured: ![]() Some Hardware ![]() Gettin her ready ![]() Tearin her apart ![]() ![]() I was very impatient, installed these in a few hours after the kit arrived....so soon that I forgot to take pictures....my bad ![]() ![]() ![]() ![]() ![]() ![]() Instructions tell me not to install headers before oil filter relocation....BLAH! ![]() ![]() I did not use the hardware that came witht he kit for the header bolts....I used "Stage 8" Bolts as I have always had great luck with them. I ALSO (which I may regret) decided to use the header gaskets that came with this kit....they are the cheapo type....but I want to use the kit as it is. Anyone including myself can make a kit work, or "better" than it comes....but I have a feeling that this stock motor wont last too long....so I will coat everything and use better stuff the next go around. Here is the "GT" lower radiator hose I decided to use. I chose to get rid of the 4V style system, to create some additional clearance for the piping in that area. I am installing a Meziere Billet T-Stat housing, along with a Meziere 180deg T-Stat ![]() VMP HPX Maf, VMP MAF Flange, VMP Harness to adapt the 05+ slot style MAF ![]() Meziere Billet T-Sta housing, and T-Stat. AWESOME PART ![]() I will have more as I go! |
Traction...?
1996 GT/ 2008 GT Vert
So your saying you want to run close to 400hp with a t45 transmission and run 10's? Personally i think the t45 is going to blow up at some point, its not the greatest transmission from the start, put with that much power you might start running into some issues unless you build it up.
I also want to see videos of this 10 second run. Kind of interested in that. ![]() Aside from that, awesome build man, keep us posted. |
RLY SRS
Nice...
I think the shift fork will fail on the T45 though... |
99 Cobra / 96 GT vert.
N/A
The shift forks will definately fail. I am NA on my 99 cobra and have already had to have it rebuilt. 3rd & 4th shift forks broke when I was racing a fox body. I only have just typical bolt ons. I plan on using this kit for my 99 build.
Looks good so far. Let us know how it all comes along. |
#5 | |
RLY SRS
#6 | |||
I don't think it will.
Here is the last one I broke/will ever break....and the new one that has been in the trans for a while now.
RLY SRS
You get it from Rob or someone else?
Bringing Yellow Back
looking good
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
Traction...?
LOL never mind, if that fork breaks or bends then something isnt right.
N/A
Dang! You right, you will not be breaking them again. Where did you get those billet forks at, and how much do they run?
2000 GT
Im installing this kit on my 2000 gt right now also, but the oil filter relocation kit they gave me dosent seem to fit, and im missing fittings for the turbo feed line. So im in a hole right now
#12 | ||
They are working on an all new CNC'd oil/coolant adapter plate type deal I believe....so THEY can provide the parts.....instead of using other manufacturers. I have been in the aftermarket automotive retail biz a LONG time, and I know what it is like to rely on others for parts....it can be a PITA. I am sure the people who do not have their fittings will be taken care of. If it were me, I'd just source the fittings locally, or from MSC / McMaster Carr / Grainger etc....to get it done. |
Didn't get a lot done last night. Goal was to solder on the MAF, finish up the Oil Filter Relocation, Gap/Install Plugs, and tap/install the oil drain fitting to oil pan. I started working at 10:00....and discovered my solder is missing, and my punch/tap necessary for the oil drain are missing..... I moved recently, and believe those are at my other house...
I was able to install the new NGK TR6 plugs. They were pretty much "pre-gapped" at where I wanted them, but I regapped them anyways.... ![]() I also went ahead and cleaned the area where I will be installing the fitting for the oil drain. The hole needs to be 5/8" down from the top of the oil pan....and 1-7/8" to the right of the center of the second oil pan bolt (from left to right)
#14 | |
RLY SRS
2000 GT
Yea im sure thats what I will end up doing, its just kinda irritating that it didnt come with them. So can u put on the relocation kit after u put the drivers side header on? Because I would like to start putting the car back together instead of waiting on fittings.
2ndPlaceSetofSteakKnives
Hell Yeah, Sick Build! Very excited to see this all come together. What turbo did you go with? the on3 70mm or the mp70?
03' Cobra | 3.4 Whipple | SRA Swap | 99' SS | Forged 347 | YSI 16psi | 12 Bolt | 96' Cobra | On3 FF Kit | T45 Source Tranny | 3.55's | 91' GT | GT40 Intake | CAI | Headers | www.fquick.com/99Ls1fever |
#17 | |
![]() On3 70mm |
Do you have a link to that Meziere Billet T-Sta housing, and T-Stat. that you got, I really like how you ran that and how it will clean up the engine bay and remove some other the junk in the front of the motor. And then you dont have to run that polished cross over tube in the front, i really like the way you did it.
Sorry if any of this is broke english, this is hard to write on a cell phone. Also, WOW that motor and engine bay are clean!!!!
Meziere Enterprises
Thanks! I like my stuff to be clean and look good, while going as fast as possible. It's tedious....but worth it IMO. |
Sweet, Thanks Man. Are you going to try to heat wrap the hot side of the kit?
Also cant wait to see more pics and updates!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/225774-on3-performance-turbo-kit-install.html
| Thread on3 performance turbo kits (fox) | Twin Cities Mustangs Forum | BoardReader | This thread | Refback | January 30th, 2012 04:07 PM | |
| Thread 1995 GT........ON3 Performance Turbo Kit Build | Corral.net: Ford Mustang Forums | BoardReader | This thread | Refback | September 19th, 2011 04:49 PM | |
| Thread Turbo Build couple of questions (on3 performance) | Forums at Modded Mustangs | BoardReader | This thread | Refback | August 19th, 2011 02:48 PM | |
Threads Similar to: On3 Performance Turbo Kit Install
| on 3 performance turbo kit | turbosilverstang206 | 99-04 | 71 | September 9th, 2011 12:15 PM |
| On 3 performance turbo kit | GTstang98 | 96-98 | 4 | August 21st, 2011 01:17 PM |
| HP Performance Turbo??? | menace07 | 2005 - 2010 | 7 | February 16th, 2010 11:26 PM |
| On 3 performance turbo | cyberdude47 | 99-04 | 14 | December 19th, 2009 07:00 PM |
| hp performance turbo | mr87 | General Tech | 10 | May 26th, 2008 04:38 PM |
