97 gt no start.....
Old July 13th, 2011, 10:18 PM   #1
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
mtw002 is on a distinguished road
Send a message via AIM to mtw002 Send a message via MSN to mtw002 Send a message via Yahoo to mtw002
97 gt PI teskid build
Ok so i picked up a 97 gt mustang the other day. I traded off a 244,444 mile 92 suburban for a non running coupe.
The guy said it over heated and quit running. I put a good battery in it and it seems to be turning over. I wont know for sure until i have someone turn it over while i'm watching. Anyway. It was completely out of radiator fluid so since i had some lying around i poured a little in it. Figured a little is better than none. But before i started to pour it i noticed 2 little pieces of metal laying in the fluid tank.
So then i got suspicious. and removed the thermostat housing. Low and behold there is no thermostat in there.
Where the hell could it have gone? i have a hard time believing it got sucked in the motor to where it wont let it start, but i really dont know.
Cars Dont Power The Front Wheels, They Lift Them
4v teksid block w/2v heads FINISHED 14 April 2010
2003 vert gt 2v teskid build 12.7 @ 107 (SOLD)
1989 mustang lx
Old July 13th, 2011, 10:43 PM   #2
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
thats motor sounds very fishy...lucky it even cranked
Old July 13th, 2011, 10:47 PM   #3
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
Well I figured i'd try to get it started. I'm going to build another teskid 2v and swap in. It would just be nice to hear it start so i know all of the supporting components work.
1989 mustang lx
Old July 13th, 2011, 11:49 PM   #4
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
Man, if you come across a 96 or 97 mark viii 4v engine pick that up instead.
Old July 14th, 2011, 12:58 AM   #5
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
...if they made it in the fluid tank...somethings wrong.
The line to the fluid tank is only about 1/2 inch lol.
2 metal peices > physics
410rwhp 520rwtq @ 12.9 psi
Old July 14th, 2011, 02:15 AM   #6
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
I don't beleive that to be the thermostat. Physically impossible. Its prob the cap to the tank and it fell apart. IDK
But hey Mike. I want those wheels! Those are my fav!
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
01 Bullitt-32v swapped
96 GT-Cammed E85
www.KPERacing.com
Old July 14th, 2011, 03:23 AM   #7
Mohater is on a distinguished road
Wow, flashback to Oki. Did you make sure there wasn't a milkshake before you cranked it? That bottom end might not yet be wasted after all. You can start it to see if it starts bone dry without wasting any coolant. How'd you pull it home?
Old July 14th, 2011, 09:20 AM   #8
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
Pulled it home with the suburban then he drove the suburban back lol.
1989 mustang lx
Old July 14th, 2011, 09:24 AM   #9
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
2 metal pieces > physics
That's what i think also but the thermostat housing had looked to never been off. I have a hard time believing it also. But if not that still leaves the question as to where the thermostat went.
1989 mustang lx
Old July 14th, 2011, 09:36 AM   #10
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
^ Some ppl think that removing them will make the car run better and faster, but keeping the motor cold...what they don't know is the car never getting warm will keep it in 'cold' start mode and it will never swap over to warm fuel tables and run rich all the time, making it actually slower...and worse MPG...
96 GT-Cammed E85
www.KPERacing.com
Old July 14th, 2011, 09:49 AM   #11
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
I'm aware of that. I'll head over in a bit and pull a plug and see if its getting spark. I swear its getting fuel because i can smell it when i crank it over. And I'm hoping its not a pats problem.
1989 mustang lx
Old July 14th, 2011, 12:41 PM   #12
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
OK so after going back over and looking at it. It is turning over and pumping fuel out the (L) exhaust pipe. Checking for spark. If no spark on (L) side i'll check the (R). If spark on (R) side i'll swap coil packs and see if maybe its just a bad coil.
1989 mustang lx
Old July 14th, 2011, 01:42 PM   #13
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
What i thought was fuel pumping out of the exhaust turned out to be just water. So i checked the oil again. I must have over looked the milkiness of the oil. I pulled 2 plugs and found them both wet. Once letting them dry i checked for spark and had spark. So Now i'm thinking its a blown head gasket on the drivers side. Should i just be cheap and slap a head gasket on it, or should get the pi swap stuff and do another pi swapped teskid motor?
1989 mustang lx
Old July 14th, 2011, 01:48 PM   #14
You need to pull the heads and see if one or both are warped, check the deck of the block too. Then there's the uncertainty of the bearings, if he ran it long enough to wash them out.
Old July 14th, 2011, 01:54 PM   #15
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
I'm going to drain the oil dry the plugs and put some used oil i have lying around in it and drain the radiator. Just to see if it will even start. I've got a set of pi heads and intake. but I need cams. And i think i'll want to use N/A cams this time.
1989 mustang lx
Old July 14th, 2011, 02:34 PM   #16
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
Head I doubt are warped. Thats the best part about huge modular heads...hard to warp them. Trust me.
96 GT-Cammed E85
www.KPERacing.com
Old July 14th, 2011, 02:37 PM   #17
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
Dibs on the wheels.
96 GT-Cammed E85
www.KPERacing.com
Old July 14th, 2011, 11:16 PM   #18
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
Well I got the 4v block tore down to a short block. Hopefully I'll get the PI heads tomorrow or tonight.
And Matt I forgot but the cams that come with the heads are actually off my 03 gt.
anyone need some 4v B heads?
1989 mustang lx
Old July 14th, 2011, 11:43 PM   #19
GMoney98's Avatar
1998 Mustang GT
13.22@106.42
GMoney98 is on a distinguished road
i got new pi cams for sale if needed and npi heads
PI Heads & Intake\ Hitech Stage 2 Cams\ Borla Cat-Back\ O/R X pipe\ BBK Shorties\ 3.73 Gears\ BBK CIA\ BBK 78mm TB&P\ BBK U/P\ B&M Shifter\ Diablo tuned\ Eibach springs\ Tokico D-spec adj\ CC plates\ Eibach F/R sway bars\ Sub-F cn\ 290rw ponys
Old July 14th, 2011, 11:52 PM   #20
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
Thanks but i already have a set of PI heads and cams.
1989 mustang lx
Threads Similar to: 97 gt no start.....
Rolling start compared to standing start PhillyGT 5.0 Mustangs 23 January 25th, 2012 09:49 PM
multiple cranks to start now no start JFSTANG V6 Mustangs 10 November 14th, 2010 11:57 PM
06 mustang gt smokes on start up and idles bad on start up slick06gt 2005 - 2010 23 September 30th, 2010 04:18 PM
Where to start, where to start... LanceD V6 Mustangs 36 March 5th, 2007 02:23 AM
