98 GT Exhaust
Old July 18th, 2011, 01:18 AM   #1
98 Mustang GT
commandeered98GT is on a distinguished road
98 GT Exhaust
Does having mufflers increase HP? logically, they create resistance and back pressure, which would decrease HP. Currently I only have the stock H-Pipe with straight pipes, no mufflers. I was thinkin about getting some flowmaster 40's, or perhaps even 10's. Would flowmasters help, inhibit, or go unnoticed in the HP department?
Old July 18th, 2011, 01:32 AM   #2
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
Will sound better but i doubt you will see much power difference on an NPI N/A, but the NPI needs all the power it can gain.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old July 18th, 2011, 12:31 PM   #3
98 Mustang GT
whats an NPI? non-performance improvement?
Old July 18th, 2011, 12:52 PM   #4
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Non -Power Improved.
No, mufflers do not add HP.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old July 20th, 2011, 02:41 PM   #5
Authorized Vendor
flowmann is on a distinguished road
Commandeered98GT – If you’re comparing a stock exhaust system on a 2011 5.0 to a Pro-Series Flowmaster Cat-Back system (for instance)…Yes! You can increase your HP and torque. We don’t release an exhaust system unless it gains power over the stock setup. If you’re asking if switching from a pair of aftermarket brand mufflers to a pair Flowmaster Super 40 mufflers, you may or may not notice a difference in power. You’ll notice a difference in sound and volume. Every exhaust system is different and for optimum power, your muffler needs will differ, so getting the right mufflers will affect the end result. Some mufflers will rob power especially on a street car in the normal operating RPM range. Also consider, if one brand lowers output by 10 hp and another brand lowers output by 5 hp, it’s fairly nominal on a 300+hp car, but which muffler would you want? Or would sound matter more to you?
Most people simply install Flowmaster mufflers for sound and the power concern is secondary.
Flowmaster mufflers are designed to increase velocity in the exhaust system to increase flow, not restrict flow and create back pressure. A perfectly tuned system will have zero back pressure. You don’t want positive back pressure or too little of it. You want zero. It’s not easy to accomplish. Zero back pressure lets the exhaust system use velocity to move the gases from the engine to out the tailpipe fastest. That’s how you create power, or at best…don’t rob power.
Flowmaster Mufflers
Toll Free Technical Support: 1-800-544-4761
www.flowmastermufflers.com
www.facebook.com/FlowmasterMufflersINC
Old July 20th, 2011, 03:16 PM   #6
WhiteNoise's Avatar
1997 Mustang GT
WhiteNoise will become famous soon enough
wouldn't straight pipes create the least resistance (nothing holding it back...)?
Mods: MAC o/r H, SCT tuner, CAI, short throw shifter, dash LED conversion Upcoming: Suspension build (Spring/Summer 2012)
Old July 25th, 2011, 03:00 PM   #7
98 Mustang GT
thats what i woulda figured. But apparently on dirtbikes, a muffler adds HP. and i dont know, er'one is sayin that the difference be it + or - goes unnoticed.
Threads Similar to: 98 GT Exhaust
Custom exhaust vs After Market exhaust (2000 gt) tdp32 99-04 11 June 7th, 2010 12:04 PM
hanging exhaust/custom exhaust patwrecked 5.0 Mustangs 5 June 3rd, 2008 12:24 AM
Dual exhaust better then side exit exhaust? boblongtv V6 Mustangs 24 January 11th, 2008 08:56 AM
