96 mustang. new head and runs like s**t
Old July 19th, 2011, 07:42 PM   #1
mustang gt 96 is on a distinguished road
ok guys this is what i have. 96 gt 4.6 over heating. took passenger side head off had it pressure checked and it was cracked on #3 cylinder. got new "used" head and had it checked and decked everything look great no leaks or anything. put the head on got it all buttoned up and runs like s**t. replaced all plugs, wires, flushed out injectors and rails still no change. checked the compression 140-150psi across the board. which should be enough for the deep dished forged pistons that are in it. im running out of ideas any help would be appreciated.
Old July 19th, 2011, 07:43 PM   #2
also re timed it twice just to make sure it was in time.
Old July 19th, 2011, 09:11 PM   #3
JasinEdward is on a distinguished road
are you using the cam from the damaged head?
Old July 19th, 2011, 10:23 PM   #4
yes. using the cam lifters and rockers from the old head. but the car ran fine before just pressurized the coolant system.
Old July 19th, 2011, 11:18 PM   #5
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
"deep dished forged pistons"
Is it tuned for that ? it might need different timing. there is a chance that the timing is off on it, pull the front cover and check it again.
Before you do that unhook the battery reset the ECU and check that. Might need a tune . Also check the cam shaft position sensor wife and crank trigger wheel...just to name a few. Also make sure your front O2 are plugged in .
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old July 19th, 2011, 11:25 PM   #6
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
and cels?
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old July 20th, 2011, 12:52 AM   #7
No cel's. I've put this motor in time a couple times before the same way and its ran fine every time. The thing is it will fire right up no hesitations. But as soon as it idles down it just starts missin. Also has new coil packs. Im thinkin injector but not sure?
Old July 20th, 2011, 12:54 AM   #8
And it has the pistons because of the svo s/c kit on it.
Old July 20th, 2011, 12:59 AM   #9
p4ndiamond's Avatar
14.80 No traction
sounds like vaccume then . check IAC...check vaccume lines and intake sealing. also might be something like the TPS.... sounds sensor related or tune.
Old July 20th, 2011, 01:30 AM   #10
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Lol did you tighten the head gasket properly? You said it ran fine before you pressurized the coolant system
410rwhp 520rwtq @ 12.9 psi
Old July 20th, 2011, 11:42 AM   #11
ya it got tightened down correctly. and it ran fine with the other head on it just the crack caused the head to pressurize.
Old July 20th, 2011, 07:37 PM   #12
zdkel's Avatar
zdkel is on a distinguished road
Aftermarket head studs or Ford Torque To Yield studs??
96 GT - PI Intake & cams, O/R h-pipe, Flowmasters - 40s, Short Throw Shifter, 3.73 FRPP gears.
Old July 20th, 2011, 09:15 PM   #13
ford torque to yield bolts. idk what the heck is goin on with this thing. whatever you do to it doesnt change a dam thing lol
Old July 20th, 2011, 09:25 PM   #14
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
Wait did you get new ones or re use them?
Old July 20th, 2011, 10:08 PM   #15
new bolts and new gasket. pulled all four plugs out of the pass side head all fouled.
Threads Similar to: 96 mustang. new head and runs like s**t
why my 2000 v6 mustang runs rough miguelj7685 V6 Mustangs 10 February 5th, 2011 10:47 AM
Mustang wont start, runs bad. Please help!!!!! ACaldy17 99-04 17 October 14th, 2010 10:46 PM
95 mustang gt runs like crap kyleboyd 94-95 29 July 21st, 2010 10:36 AM
2011 Mustang 5.0 runs 12.04@117!! riceburnin03 2005 - 2010 10 May 10th, 2010 10:38 PM
Mustang runs like a slug MIGHTYJO3YOUNG V6 Mustangs 33 May 16th, 2008 07:12 PM
