Washing
Old May 15th, 2007, 09:16 PM   #1
Proud American
MustangMatt96GT's Avatar
Washing
What type of clay bar system do you guys suggest? I need some new car wash concentrate as well! I have the turtle wax ICE and am happy with it, but I am open for suggestions on that as well! Basically what I would like to know is what products do you guys use on your stangs? Mine is kinda getting emmbarrassing to drive because it has had to sit out side for the last month and everytime I washed it, it rained and I couldnt wax it!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old May 15th, 2007, 10:29 PM   #2
98SilverBullet is on a distinguished road
I have been using Armoral Gel (?), it's ok. I need to get a drying rag cause water spots suck.
'98 Mustang GT
CAI, X-Pipe, Pypes Catback, Tri-Ax
'96 Eclipse Gs-T
Drop In K/N, T-2Gay @ 15psi, BSEK
Old May 16th, 2007, 12:37 AM   #3
96 GT
slightly stoopid is on a distinguished road
dont use a clay bar unless ur getting out scratches. just use compound was and apply it with a power buffer on all the metal, and use a buffer with a sponge like pad to burn it off where theres spots the rest can be taken off by hand. once u do this once just wax it every 2 months or so.. o h ya i detail cars for a living
BBK cold air intake, flomaster 40 series, steeda tri ax short throw, bbk x pipe w/cats, black magic fan, 3.73 gears, bbk pulleys, 18/10 18/9 black bullitts black with chrome lip....
Old May 16th, 2007, 12:37 AM   #4
96 GT
* compound wax
Old May 16th, 2007, 12:52 AM   #5
1998 SVT Mustang Cobra
1998_svt_cobra is on a distinguished road
I have really hard water around here and i po's me to hand wash it, so i go to a self serve wash place and wash it and then spotless rinse it. by the time i get home, it's halfway dried of and i dry off the finishing touches to it. I've gotten really good washing it and i only spend 1.50 per wash
Kennebell 2.1L Twin Screw soon tooooo cooome!
__________________^__________________
IT'S WATCHING YOU VETTE BOY
Old May 16th, 2007, 01:25 AM   #6
beheivjer's Avatar
beheivjer is on a distinguished road
meguires clay bar and fast wax kit
1969 Early Bronco 3.5" lift 37" swampers
1969 Early Bronco 2" lift half cab
1979 2.3t Cobra
1997 Black Cobra
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Old May 16th, 2007, 04:52 PM   #7
Proud American
Well I do need to use a clay bar, because it has never had one on it its whole life, and I do have a lot of contaiments including scratches! After I do the clay bar should I the use compound wax? Thanks
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old May 16th, 2007, 06:21 PM   #8
Ccash00 is on a distinguished road
Use a clay bar for contaminents it does nothing for scratches for those you would need a real buffer not one of those things just for waxing and use a mild compound like finesse or I like meguiers diamond cut
Old May 16th, 2007, 07:01 PM   #9
96 GT
the clay bar will help get out the impurities, but that meguiers diamond diamond cut is good shit specially when u cut it down with a buffer, after that the regular wax should build up the clear coat
Old May 16th, 2007, 07:18 PM   #10
1997 Mustang GT
untamed97stang is on a distinguished road
I agree with the above. Also slightly stoopid and behievjer.
Mequiars makes really good car detailing products. Use the clay bar only to remove dirt from paint from the clear coat., its not going to remove deep dirt or paint imperfections. Please make sure you use a lubricant provided or a soapy water when doing this. When you are done with the clay get you a good high speed buffer and a good compound. Gives a deeper shine. Then if you have a orbital buffer and a good wax, do an even coat and take it off with a cheese cloth or a cotton tshirt and you will be smiling for days with your new car shine!
Old May 16th, 2007, 11:28 PM   #11
Proud American
Can somebody link a good compound for me! And then what type of wax do you guys suggest? Is the meguires diamond cut a compound?
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old May 17th, 2007, 10:19 AM   #12
beheivjer's Avatar
i like to use the meguires cleaner wax for small scratches and imperfections.
1979 2.3t Cobra
1997 Black Cobra
Old May 17th, 2007, 02:29 PM   #13
DragonFreak is on a distinguished road
Send a message via MSN to DragonFreak
diamond cut is a compound not a wax....use the clay bar then use a real gental compound on it...if you have never used a high speed buffer i wouldnt do it then cuz you coul burn the paint...after the compound use a glaze and you wont have to wax it...most glazes have a clear coat protectant in them now days...
Old May 17th, 2007, 08:47 PM   #14
Proud American
okay so i bought a mothers clay bar kit and some turtle wax polishing compound and then after wards I will use my Turtle wax ICE! hope i have enough time to do this tommarow!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old May 18th, 2007, 12:02 AM   #15
ujslost's Avatar
Matt sup bro. Dont do the highspeed buffer yourself, you will burn the paint. Check around some local detail shops or talk to someone that cleans up cars at a carlot and see what they would charge you to "wheel" your car for you. Most around here are around $100-$125 and its worth it to let them do it, they will polish and wax it also.
Old May 18th, 2007, 01:16 AM   #16
Proud American
I am definatly not using a high speed buffer! I am just going to wash it, dry it, clay bar it, compound polish it by hand, and then wax it! lol it should be a long day! I hope I can get it all done before 3:30 when I leave for work! I think I am going to get up extra early on the first day of summer beack to wash and polish my car lol
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old May 18th, 2007, 08:53 AM   #17
ujslost's Avatar
good luck matt , its gonna be a long day
Old May 18th, 2007, 11:25 AM   #18
Proud American
Yeah I know!!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old May 19th, 2007, 12:10 AM   #19
Proud American
Okay so Ill I got done today was the clay barring before I had to mow some lawns! And all I can say is WOW!! Its the best thing I have everdone for my cars exterior! It made the paint as smooth as glass! It only took me around an hour and a half to finish my whole car and it feels and looks amazing! Tommarow night after work I will polish it and see how that looks!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old May 19th, 2007, 12:17 AM   #20
ujslost's Avatar
good job bro!
Threads Similar to: Washing
Washing Engine mustangmanic 99-04 19 November 12th, 2007 03:25 PM
washing tips aintsheperty66 Classic Mustangs 4 July 23rd, 2007 03:27 PM
Washing frequently? MustanG_guy17 Visual 125 April 23rd, 2007 12:37 PM
washing that dirty 4.6 greenwood Modular Mustangs 7 February 1st, 2007 08:59 AM
Tips For Washing Your Car? mdvaldosta Visual 29 September 22nd, 2006 12:55 AM
