Driving my car last night.
Old July 21st, 2011, 05:34 PM   #1
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
The car popped two codes.
p0135 - This code refers to the front oxygen sensor on Bank 1. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0135.
Any tips on fixing that one, were is that o2 sensor exactly?
p1405 - Differential pressure feedback sensor upstream hose off or plugged
I read online
"The Differential feedback pressure sensor is located under the hood on the drivers side.
If you locate your EGR valve you will see a tube going from it to your exhaust manifold.
you will notice 2 small tubes leading from the large one feeding into a small sensor....this is the DPFE sensor which is throwing your code.
Now....the DPFE "could" be doing its job by telling you the orfice in the tube is plugged, but the DPFE is known to fail on these trucks.....but it throws a code P401....
It may be a good idea to try a new DPFE sensor before a new EGR tube."
Does that sound right?
Any tips to help me fix this?
Old July 22nd, 2011, 03:51 PM   #2
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
1. The o2 sensor is located on your midpipe. If you get under your car you will see where they go into the pipe. There is one on each side before the catalytic converters and one on each side after the catylitic converters. The front is the one before the cats.
2. the chance that your egr tube is blocked is extremely small. I would replace the DPFE sensor after checking to make sure the egr tube is not dented or kinked. It is a metal tube so if it hasn't been messed with by a previous owner it should be fine.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old July 22nd, 2011, 04:06 PM   #3
MM's Samsquanch
OneShotOneKill's Avatar
1998 GT
OneShotOneKill will become famous soon enough
you are making me thing of a Diesel particulate filter off of a latemodel diesel truck lol
MILITARY CREW
USMC
E-4
Old July 22nd, 2011, 11:42 PM   #4
Traction...?
1996 GT's Avatar
I copied and pasted off a 4.6 f150 site.
How hard are my front two to get at?
Is the DPFE sensor important? What will it do to my car?
Also thanks man.
Old July 23rd, 2011, 02:54 AM   #5
MM's Samsquanch
1998 GT
the 02 sensors are very easy to replace, just unclip them from the wiring harness then use a wrench to screw them out.
MILITARY CREW
USMC
E-4
Old July 23rd, 2011, 09:18 AM   #6
Traction...?
1996 GT's Avatar
Are you talking about the downstream ones? i know those ones are super easy to get to, i was wondering about the up stream ones.
Bank one is drivers side right?
Old July 23rd, 2011, 09:54 AM   #7
1996 Mustang GT Vert
Blower Head is on a distinguished road
Bank one is the passenger side.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's
Old July 23rd, 2011, 12:54 PM   #8
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Upstream are not that hard to get to either. Those are the two that control your a/f ratios and determine how your car runs. The two downstream sensors just monitor the efficiency of the cats.
Use a 7/8 open end wrench to get them off. They should come out pretty easy once you break them loose. Make sure to put a little anti sieze on the threads of the new ones when you install them. That will make removing them in the future 10x easier.
MODS IN GARAGE
NCMM ORIGINAL
Old July 23rd, 2011, 02:30 PM   #9
Traction...?
1996 GT's Avatar
Thanks guys! Much appreciated.
One last thing, how can i test them to see if they work okay?
Old July 24th, 2011, 02:59 AM   #10
MM's Samsquanch
1998 GT
well the easy way would be to swap sides, back when my car was throwing codes for the upstream i just unplugged my battery, swapped the driverside 02 with the passenger 02, re-connected battery and waited for the corresponding code to come up just for opposite side. that way you know for sure its that certain sensor going bad
MILITARY CREW
USMC
E-4
Old July 24th, 2011, 11:46 PM   #11
Traction...?
1996 GT's Avatar
Fair enough, i might just do both of them, i can get two walker o2 sensors for 75 $.
Old July 25th, 2011, 02:24 AM   #12
MM's Samsquanch
1998 GT
RockAuto Parts Catalog
thats the link for 98's but i doubt your 02's are different, you can get them from $25 a piece up to $38 a piece for the motorcraft ones...i bought a bosch 02 from o'reilys for like $60 before i knew about rockauto...they have the same one on the site for $36.79
MILITARY CREW
USMC
E-4
Old July 25th, 2011, 01:21 PM   #13
Traction...?
1996 GT's Avatar
Yeah ive used rock auto for many things before, but im in canada so shipping is a little more, sometimes it is still cheaper or its more. All depends.
Old July 25th, 2011, 01:21 PM   #14
Traction...?
1996 GT's Avatar
Threads Similar to: Driving my car last night.
Xbox..........Tonight...or tomorrow night...or the night after that Smoothgrandmama The Clubhouse 19 July 8th, 2010 11:33 AM
Moday night MM poker night? No Football for a while.. chad05gt The Clubhouse 13 March 15th, 2009 10:19 PM
I was driving home last night... Dansby The Clubhouse 32 August 6th, 2008 12:53 PM
South Florida Cruise Night - Every Saturday Night JohnnyZ Southeast 0 July 20th, 2008 10:48 AM
Friday night Street Night - Richmond Drag L33T Southeast 9 June 19th, 2007 10:32 PM
