4th cylinder misfiring and over heating... help!
Old July 22nd, 2011, 08:50 PM   #1
'97 Mustang GT
ponyboyy is on a distinguished road
Ok so about a month ago I swapped my cracked intake manifold on my '97 gt with another newer non-pi intake manifold. Well when I pulled off the manifold a little bit of coolant dripped into the spark plug hole for cylinder 4. When I started it up it was misfiring BAD. So I used some compressed air to get the coolant out and replaced the spark plug. It helped a WHOLE lot, but it was still misfiring quite a bit. So then I replaced the corresponding ignition coil. And that helped a WHOLE lot as well. Then, it started misfiring pretty bad again. I popped the hood and started it and fuel was spraying out. So I tightened the fuel rail down. And then the engine was running perfect. But here lately my engine has been getting really hot. Not necessarily over heating, but it heats up all the way to the A on NORMAL. I've checked my coolant and oil, and both was good. So any ideas why its heating up? And when I romp on it I hear a very slight misfire when I'm in 1st gear, and a slight power loss. The spark plug wire seems fine, and I don't see any leaks. Any ideas??
Oh also, my cooling fan has been extremely loud lately, could the motor on it be going out and causing the heating problem?
Thanks a lot in advance!
Old July 22nd, 2011, 09:26 PM   #2
98BAGT is on a distinguished road
bad cooling fan possible if its making noise. i would throw some lucas top engine cleaner in it because that always helps alot and change your fuel filter.
14.3 @ 99.18 im slow
Old July 22nd, 2011, 11:54 PM   #3
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
Yep^ Or fuel injector cleaner, they might be able to work to their full potential.
Old July 23rd, 2011, 07:12 AM   #4
'97 Mustang GT
to fix cooling or misfiring?
someone mentioned to me to replace my thermostat?
Old July 23rd, 2011, 01:01 PM   #5
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I would first off make sure the fans were actually working. If they are and you hear that terrible squeeling when they kick on then I would look into replacing them. Changing your thermostat to a 160 will help with the cooling as well. Flushing your radiator may be a good idea as well. You may want to put in an in-line filter on the coolant hose first to keep the debris that will come loose from clogging your heater core.
As for the misfiring I would pull the plug again and replace it, this time use some air to spray out the hole before you reinstall it. Make sure to put some dielectric grease on the tip of the wire connector before you reconnect it. Speaking of wires, you may want to pick up a set of Ford racing wires to replace your old ones as well. When fluid sits around the plug and wire it is common for them both to get screwed up.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Threads Similar to: 4th cylinder misfiring and over heating... help!
cylinder 4 misfire and lodw compression in that cylinder.. helpppppp $GTSTUD$ 99-04 2 June 1st, 2011 12:23 AM
misfiring jazer 5.0 Mustangs 2 March 16th, 2010 05:42 AM
misfiring cylinder 1 and 3 Midnight Stang02 V6 Mustangs 4 March 16th, 2010 12:47 AM
Misfiring crazyjones V6 Mustangs 11 May 22nd, 2007 01:12 AM
98 gt misfiring? jigga99 96-98 5 April 19th, 2006 06:34 PM
