1997 Pacific Green Cobra
14.80 No traction
brake upgrade
Im on a 97 cobra on stock rotors and they are about to die. is this a good upgrade kit ?
Speed Concepts - 13CDSL-HWK-F - 1994-2004 (Front) 13" Cobra/Bullitt/Mach1 Cross Drilled Slotted ZINC plated Rotors and HAWK HPS pads kit
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
Rollin' 18/ pushin' 2
Yes, but I would look for rotors that are not drilled, just slotted. I have used drilled rotors a few times on a few different cars and they all developed cracks between the drill holes. Chances are that you are not going to be heating them up enough to actually take advantage of the drilled holes anyway.
Abyssinian of AX
'02 Saleen
19.34@42.259
While this is true, it's because one is not following proper braking techniques on the street. I have been running a set of cross-drilled rotors for a couple years with no issues of cracks. I have spend a day running around Infineon and probably 20 HPDE days on them. They are actually going to get replaced here in a few months, as I want to throw a new set on there and have the existing ones re-surfaced. I will keep them in storage for a quick swap one day. With this said, I am also running Brembo's, so probably part of the reason they have held up well
![]() Jazzer
Threads Similar to: brake upgrade
| brake upgrade | xXJayManZXx17 | 99-04 | 36 | September 24th, 2010 02:05 PM |
| Brake upgrade help | frpp2003 | 99-04 | 7 | July 24th, 2010 12:47 AM |
| Baer brake upgrade -- parking brake not working | spoulson | 5.0 Mustangs | 0 | September 30th, 2009 02:01 PM |
| Cobra brake or bullit brake upgrade | 97gtstang | 96-98 | 5 | May 14th, 2007 02:15 AM |
