Fuel system advice
Old July 23rd, 2011, 06:15 PM   #1
Doggins's Avatar
Doggins is on a distinguished road
Fuel system advice
Hey,
Just had some questions on the fuel system on the 97gt. My current fuel pump is going out (fuel pressure gauge shows fuel losing pressure when the car is off and it takes a few cycles of the key to charge it up to the correct pressure as well). I just purchased a Holley 255 LPH fuel pump and will install it next weekend.
I'm wondering with my current mods if/how I need to upgrade the injectors/MAF/fuel regulator, etc. My mods are:
CAI/PP throttlebody/accufab plenum/ P.I. intake/ ported and polished P.I. heads/ reground P.I. cams/Steeda UDP/BBK shorty headers (have a set up pypes LTs i havnt put on yet/
my injectors/MAF/FPR are all stock and I think i'm running a bit lean. I had the car tuned by houston performance so it has a diablochip in it but they were terrible and couldn't get the car to run with out detonating until they pulled a bunch of timing.Just wondering what you all think. Thanks
Old July 28th, 2011, 01:08 PM   #2
Doggins's Avatar
Any fuel system experts out there?
Old July 28th, 2011, 10:01 PM   #3
Speedstang302's Avatar
13.64@101mph
I'd say your still under the power limits for 19lb injectors... But your stock maf maybe shot...I'd say just 24lb it and lightning maf and you'll be set for a while.
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old July 28th, 2011, 10:03 PM   #4
Doggins's Avatar
so if i grab the lightning maf and some 24lb injectors, how do i calibrate? Using an SCT tuner? or do i need to go get a dyno tune for the new equipment
Old July 28th, 2011, 10:45 PM   #5
13.64@101mph
You can call up a local shop that has a licensing with sct and can email you a tune to put into your hand held tuner for usually about $30ea. But I'm pretty sure your tuner has maf and injector selections. I've only used sf3 and xcal3 and those do idk any others
Old July 31st, 2011, 02:05 AM   #6
98 GT
13.6
4.6 GT 143 is on a distinguished road
normally if you are losing pressure with key off the pressure regulator is going bad... pull the vacuum line off and see if its wet or has a heave smell of gas
Threads Similar to: Fuel system advice
Fuel System Advice? JakeM 94-95 2 January 6th, 2011 04:38 PM
(evaporative emission system) need advice 96 PI 96-98 2 September 26th, 2010 03:51 AM
need advice on fuel system.. what are you running? B0B 99-04 29 September 21st, 2009 04:03 PM
new guy looking for advice on new exhaust system! 5.0 kid New Members Introductions 14 October 24th, 2007 08:58 AM
need a little advice (coolant system 01 GT) HMUSN General Tech 4 March 21st, 2007 10:57 PM
