98 Mustang GT
Ring and Pinion
Thinkin about getting a 4.10 ratio ring and pinion set, any one know how that will effect torque and acceleration?
.... itll make you super slow bro dont do it.
we do have a search button............ but if it matters im auto and i plan on going 4.10s. |
13.64@101mph
I have 4.10's in mine there fun gears. Tend to run a little high in the rpms on the highway. It's won't add hp or tq if that's what your asking? Besides the acceleration fact all it really does is after shifts cuz of the shorter gears leaves you higher in the rpms for the next gear thus leaving you inside your power curve unlike stock gears where as your basically back at idle after shifts
98 Mustang GT
2009 Mazda Mazda6
:facepalm
He was being sarcastic.
-2004 Mustang GT: Sold..Worst mistake of my life. ![]() -2009 Mazda Mazda6 i Touring: The new whip Wish I could've kept the Mustang and the Mazda at the same time... |
98 Mustang GT
when changing from stock to say 3.73 do you need to replace any bearings or anything, such as a crush bearing? or will all the original stock stuff work?
1997 Mustang GT
i think the 3.73 is more popular on the 5 speed and 4.10 on auto, if im correct?
![]() Mods: MAC o/r H, SCT tuner, CAI, short throw shifter, dash LED conversion Upcoming: Suspension build (Spring/Summer 2012) |
13.64@101mph
Eh on foxes...I think I know 5x more mod cars with 4:10's over 3:73's
1997 Mustang GT
if the 4.10s keep u in the power range and quicker shifts, then why do dragers use the 3.73 with a longer 1st? Is is to keep them from shifting too much?
I know this is kinda off topic, but which gear is better for street racing and will allow you to get and maintain the highest speed? Lets say.. 140 mph.
13.64@101mph
Idk any drag cars running 3:73's so I can't answer that. 4.10's area plus is all I ever see
Traction...?
1996 GT/ 2008 GT Vert
Yeah i see most drag cars with a 4.10's or higher, i only see 3.73's with a c4 or c6 transmission with a ratchet shift kit.
1997 Mustang GT
but since the 4.10s let you get through the gears quicker, doesnt that hurt the overall top speed?
Rollin' 18/ pushin' 2
Yes. I would replace the bearings at the same time too. You should take the opportunity to rebuild your trac loc with carbon fiber discs as well while you have it all opened up. That way when your done then you are truelly done with the rear end work.
13.64@101mph
Not exactly just means you'll be in a lot higher rpms at those speeds. I've been 140mph with my 4.10's (on a closed course with a professional driver of course) just was a tad high in the rpms. And if my car is trapping 140+ range than it's time for a completely different setup
98 Mustang GT
would it hurt anything if you just kept the stock bearings and replaced the gears only?
Threads Similar to: Ring and Pinion
| Can I put a 8.8 ring&pinion in my 7.5? | dingo95 | V6 Mustangs | 9 | June 13th, 2011 06:51 PM |
| Ring & Pinion | flashg | 5.0 Mustangs | 5 | April 23rd, 2011 08:27 AM |
| Ring and Pinion Q? | eLLuSioNiST | 2005 - 2010 | 17 | May 11th, 2008 08:53 PM |
| Ring and Pinion Help | andres0286 | 99-04 | 4 | March 24th, 2008 03:24 PM |
| Would you buy a used ring and pinion? | mustangmanic | 99-04 | 20 | January 28th, 2008 10:59 AM |
