1998 mustang GT
problem with stalling
Ok, I just replaced the idel air control valve, the throttle positioning sensor, PCV valve & EGR valve and I still have this problem??? Any ideas on what to check next? When I first start the car it idles fine but soon as I bump the gas peddle the idle goes up (just over 1000 rpm and down (below 500 rpm) back'n forth until it stalls out or corrects it's self. I do have Cams so it is lopey at idle but normally does not stall out. It does not seem to be a vacume leak or at least I can't find one. I'll try anything to fix this...
Thanks for your imput.
98 gt blk on blk 90k miles with BBk 75mm throttle body, C&L plenum, Diablosport predator,powerdyne supercharger & a few other things. |
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
![]() iTrader: 1 reviews
you for got the main thing you should have done 1st...YOUR MAFS...these things are shit on these cars,prone to failure...how much boost you running and what kinda mafs you have?
1998 mustang GT
I'm only running about 8lbs and it is stock with a diablo MAFIA...
1996 Mustang GT Vert
I have been trying to cure a case of rolling idle ever since I put my supercharger on. Mine smooths out as soon as I put it in gear as I am running an automatic tranny. I am running a 90mm lightning maf and had my tuner spend a fair amount of time trying to cure it. I have heard that if you move your maf so it is blowing through it instead of pull through this can sometimes help.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's |
2000 GT 'vert
What methods are you using to check for vacuum leaks?
Sent from my Nexus One using AutoGuide App |
1996 mustang GT
Tuned?
1998 Mustang GT
13.22@106.42
raise your idle and see if it keeps doing it. you can adjust with ur tuner or on the tb. i had the same problem untill i set my idle around 1000.
PI Heads & Intake\ Hitech Stage 2 Cams\ Borla Cat-Back\ O/R X pipe\ BBK Shorties\ 3.73 Gears\ BBK CIA\ BBK 78mm TB&P\ BBK U/P\ B&M Shifter\ Diablo tuned\ Eibach springs\ Tokico D-spec adj\ CC plates\ Eibach F/R sway bars\ Sub-F cn\ 290rw ponys
#8 | |
1998 mustang GT
Maybe I should bump it up to 1200rpm's???/
1998 mustang GT
I had the car tuned this spring when I had a water meth kit installed. The car was running fine then had a small issue months later with the idle being to high (all on it's own no one had touched it) & now it is dropping to low & stalling out sometimes.
Threads Similar to: problem with stalling
| stalling problem | jjaramillo1995gt | 5.0 Mustangs | 1 | May 9th, 2011 01:42 PM |
| stalling problem i need help | greengoblin | 99-04 | 31 | April 8th, 2009 09:42 PM |
| stalling problem | harrylee | 5.0 Mustangs | 11 | June 3rd, 2008 06:38 PM |
| Stalling problem need help | Booger | 5.0 Mustangs | 2 | January 7th, 2007 09:07 PM |
| Stalling Problem | Mustang8719 | 5.0 Mustangs | 12 | July 27th, 2006 11:42 PM |
