t45 transmission fluid - Forums at Modded Mustangs
post #1 of 27 Old August 3rd, 2011, 01:47 PM Thread Starter
Green4.6's Avatar
Well guys I'm gonna be changing my tranny fluid since its been rather notchy lately. I was wondering what you guys would recommend, I was thinking to use royal purple, penzoil synchromesh, or Mobil 1 atf.
Pacific Green 96 Gt
Green4.6 is offline
post #2 of 27 Old August 3rd, 2011, 06:48 PM
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
i use mobil 1.... never had any problems its just kinda expensive though
1989Gt. is offline
post #3 of 27 Old August 3rd, 2011, 06:58 PM
June 2010 ROTM
Serlin's Avatar
I use Motorcraft fluid.
Ford engineers know more than I do.
Been tracking my car for 4+ years, and no issues.
Runs like a champ.
HPDE Instructor: NASA, PCA, HOD, PDG, Track Guys
www.RaceCarTowHooks.com
My Track Videos http://www.youtube.com/user/Msirlin
My Garage page: http://www.mitchsirlin.com/mustang/index.htm
Serlin is offline
post #4 of 27 Old August 3rd, 2011, 08:44 PM
iTrader: 9 reviews
use motorcraft mercon-v atf.
If you decide other wise make sure its mercon v. There is a TSB for most fords to change to mercon-v
bullitt swapped and dropped sn95 extremely hardparked
WRX wagon
ZX7R
My slow show build
MustGT98allday is offline
post #5 of 27 Old August 4th, 2011, 03:25 PM Thread Starter
Green4.6's Avatar
Does only Ford carry motorcraft mercon v, and does the tranny take 3.25q?
Pacific Green 96 Gt
Green4.6 is offline
post #6 of 27 Old August 5th, 2011, 01:34 AM
philly101's Avatar
How much do u have to put n a empty t45
philly101 is offline
post #7 of 27 Old August 6th, 2011, 07:49 PM Thread Starter
Green4.6's Avatar
Anyone
Pacific Green 96 Gt
Green4.6 is offline
post #8 of 27 Old August 6th, 2011, 07:59 PM
Resident asshole
Forget mobil. Amsoil synchromesh and put in 3.5 liters if I remember correctly. When I first bought mine it was a bit notchy. Amsoil corrected that. Royal purple is good too. I wont support mobil. They pulled a fast one on the consumer. I would call it fraud personally so they make none of my money.
Black 2000 gt with a Mach 1 4v. 3.90 gears.Mac long tubes,prochamber,nitrous.
1988 5.0
1982 Capri RS Turbo 1 of 22 built,putting today's tech into yesterday's style.
Shredding Rubber is offline
post #9 of 27 Old August 6th, 2011, 10:09 PM Thread Starter
Green4.6's Avatar
what did Mobil do just wondering?
Pacific Green 96 Gt
Green4.6 is offline
post #10 of 27 Old August 6th, 2011, 10:16 PM
bigjohnstud4200's Avatar
M/T - Mercon(R) V ATF Usage Information
TSB 06-26-1
01/08/07
MERCON ATF IS BEING REPLACED BY MERCON V
AS A SERVICE FLUID FOR SOME MANUAL
TRANSMISSIONS
FORD:
1981-2003 Escort
1984-1995 Thunderbird
1985-2007 Mustang
1985-1996 Bronco
1985-2007 Ranger
1986-1997 Aerostar
1991-2004 Explorer
1995-2007 F-150
1996-2007 F-Super Duty
2001-2003 Explorer Sport Trac, Explorer Sport
LINCOLN:
2001-2002 Lincoln LS
MERCURY:
1984-1995 Cougar
1987-1999 Tracer
ISSUE
MERCON(R) Automatic Transmission Fluid is being replaced by MERCON(R) V as the service fluid for manual transmissions originally requiring MERCON(R).
ACTION
Beginning immediately all manual transmission applications requiring MERCON(R) can now be serviced using MERCON(R) V or MERCON(R) Automatic Transmission Fluid or dual usage fluids labeled MERCON(R) / MERCON(R) V. After July 1, 2007, MERCON(R) Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will continue until remaining inventory has been depleted.
SERVICE PROCEDURE
Approx, 3.1 Quarts
Tuned by Joe@TrickTuners
CMS Stage 1 Cams, 4.10 Gears, TrickFlow 70mm TB & Plenum, MAC Prochamber with Pypes M80's, MGW Shifter, Custom Paint, Cobra Cloth Top, Staggered Chrome 18" Saleen's and Sequential Tails.
bigjohnstud4200 is offline
post #11 of 27 Old August 6th, 2011, 10:46 PM
i put in pennzoil synchromesh and made the transmission shift like a dream. i think i put 3.25 qts or so in there.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, 10 lbs, lee blankenship tune 430/405
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
mustanginky is offline
post #12 of 27 Old August 7th, 2011, 03:11 AM Thread Starter
Green4.6's Avatar
It seems like everyone has a different preference, I have no clue what to choose. Might just go with motorcraft mercon v.
Pacific Green 96 Gt
Green4.6 is offline
post #13 of 27 Old August 10th, 2011, 08:40 PM Thread Starter
Green4.6's Avatar
Is there a difference between the normal motorcraft mercon v and the synthetic blend motorcraft mercon v. Because I just bought the normal kind and want to make sure I didn't get the wrong one
Pacific Green 96 Gt
Green4.6 is offline
post #14 of 27 Old August 11th, 2011, 12:27 PM
Authorized Vendor
BMR Tech's Avatar
I use what my builder recommends.
Most people who are knowledgeable with the T45 recommend the same.
Mercon V
I have spoken with Tremec, and they advised me not to run any of the Synchromesh products (GM / Pennzoil / Etc) in my T45's.
I used Pennzoil Synchro for years (1999 - 2005) in my T45's and never had an issue, but it did seem that they became "notchier" sooner with the Synchro than the regular ATF.
I have made 3,000+ track passes with T45's.
BMR Tech is offline
post #15 of 27 Old August 12th, 2011, 11:16 PM Thread Starter
Green4.6's Avatar
I just got done changing my fluid and 4qt came out and I put 3.25q in. Should I put more in?
Pacific Green 96 Gt
Green4.6 is offline
post #16 of 27 Old August 13th, 2011, 01:33 AM
I would not.
post #17 of 27 Old August 13th, 2011, 03:33 PM Thread Starter
Green4.6's Avatar
Originally Posted by bigjohnstud4200 View Post
I would not.
Alright thanks, I was a bit worried that 4qt came out
Pacific Green 96 Gt
Green4.6 is offline
post #18 of 27 Old August 13th, 2011, 08:45 PM
iTrader: 9 reviews
just make sure you car is on a flat surface and fill it to the bottom of the fill hole. Thats the correct level.
WRX wagon
ZX7R
My slow show build
post #19 of 27 Old August 13th, 2011, 09:41 PM Thread Starter
Green4.6's Avatar
I didn't even remove the fill plug. I made sure I put exactly 3.25q in
Pacific Green 96 Gt
Green4.6 is offline
post #20 of 27 Old August 13th, 2011, 10:56 PM
iTrader: 9 reviews
how did you fill it?
WRX wagon
ZX7R
My slow show build
Human Verification
