Alright ford techs Need help diagnosing DTC's
Old May 18th, 2007, 05:41 PM   #1
product1620's Avatar
98 GT
14.60 @ 94.78mph
product1620 is on a distinguished road
Send a message via AIM to product1620
I just got my sct livewire tuner yesterday, I don't have cats so my check engine light stays on, so I checked my DTC's and I got three codes:
p1443
p0420
p0430
Then today I uploaded my new tune, did a hp run, and got a base number, then I set it back to stock, and did another run (ass backwards, I know) afterward I decided to check my DTC's again, and this time I only got two codes:
P1000
P1260
My question is, what do these codes mean, and why did they change in the matter of a day?
Thanks
Phil
1998 GT
FRPP: 4.10s, Alluminum d/s
STEEDA:upper/lowers, springs, cc plates, tri-ax
TOKICO: Adjustable shocks
SPEC: alluminum flywheel
K&N: Intake
Screamin Demon ignition
ram: clutch
BUCK OFAMA
Old May 18th, 2007, 05:53 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
scroll down a little on this link and you will see what the coeds mean
http://www.obd-codes.com/trouble_codes/ford/
Old May 18th, 2007, 10:47 PM   #3
ujslost's Avatar
1000 is obd II monitor testing incomplete
1260 is theft detected engine disabled
1443 evaporative emission control system-vacuum system- purge control solenoid or purge control valve fault
0402 is egr flow excessive at idle
0430 is catalyst system efficiency below limit- bank no 2
My guess is you have the cats cut off or an off road mid pipe and you dont have the MIL eliminators correct? thats the 0430 , or you need an O2 sensor on the drivers side.
I have been getting the 0402,and 1443 on my car. I have a purge valve on the canister that is faulty apparently
Old May 19th, 2007, 02:11 AM   #4
98 GT
14.60 @ 94.78mph
Yes, I have an off road pipe, with no cats, I just wanted to make sure, that the codes I was getting were because of that.
1998 GT
K&N: Intake
ram: clutch
BUCK OFAMA
Threads Similar to: Alright ford techs Need help diagnosing DTC's
alright need help 40thmustanggt 99-04 5 November 4th, 2007 10:39 AM
alright wtf MSO The Clubhouse 49 October 31st, 2007 11:31 PM
need help diagnosing sonicblue 5.0 Mustangs 18 October 23rd, 2007 10:02 PM
DTC's Ryno 99-04 7 May 5th, 2007 05:56 PM
computer dtc's not showing?????? stang fanatic 5.0 Mustangs 5 May 15th, 2006 11:05 PM
