gas filler neck
Old May 21st, 2007, 08:10 PM   #1
DragonFreak is on a distinguished road
Send a message via MSN to DragonFreak
gas filler neck
ok i have a leak around the filler neck i guess from where i replaced the fuel pump...how do i fix this its where the neck goes into the tank lol
Old May 21st, 2007, 08:54 PM   #2
droppedbass87 is an unknown quantity at this point
Send a message via AIM to droppedbass87
i had it leaking out where the filler neck goes into the side of the gas tank..its a rubber piece that the filler tube goes into so it doesnt leak out..its a rubber gasket..
Old May 21st, 2007, 09:17 PM   #3
ok so how do i fix it lol
Old May 21st, 2007, 09:27 PM   #4
beheivjer's Avatar
beheivjer is on a distinguished road
go to the dealer and replace it or go to the parts store and get some stuff called seal-all and just goop it up over there and let it dry
1969 Early Bronco 3.5" lift 37" swampers
1969 Early Bronco 2" lift half cab
1979 2.3t Cobra
1997 Black Cobra
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Old May 21st, 2007, 09:55 PM   #5
ok thanx
Old May 21st, 2007, 10:25 PM   #6
no just replace it cuz theen you have a mess...but anyways you have to drop both metal straps then pull out the filler neck and you just pop it out and then put some grease on the filler neck after you pop the new seal in just dont rip it..
Threads Similar to: gas filler neck
Breather Filler Cap Garhfer 99-04 24 April 8th, 2009 12:41 AM
sore neck Luis_GT The Clubhouse 36 October 16th, 2007 05:00 PM
Red Neck Cooool garage! WAR-PARTY The Clubhouse 10 September 5th, 2007 06:19 PM
oil filler breather cap question cobralini 5.0 Mustangs 1 June 28th, 2006 05:25 PM
filler neck gasket-owned mustang_montana 96-98 2 April 30th, 2006 06:51 PM
