Discussing Speedometer in the 96-98 Forum. Hello all, I recently bought a 97 mustang GT and the speedometer does not work ...
Old May 22nd, 2007, 11:31 PM   #1
Speedometer
Hello all, I recently bought a 97 mustang GT and the speedometer does not work the guy I bought it from said it just needs a gear. He told me it has different gears in the car but he didnt know what size. Is there a way i can find out what gears are in the car without ripping it apart? Also how hard would installing the gear be for the average person?
Old May 22nd, 2007, 11:39 PM   #2
All Throttle with a Bottle
MustangMatt96GT's Avatar
12.91@105.29 @ 5800 FT
Jack up the rear end so that both rear wheels are off of the ground.
2. Put a mark on the drive shaft.
3. Have somebody spin a rear tire slowly once around and count how many times the drive shaft goes around.
4. If it goes around 3 and 3/4 times you have 3.73s If it goes just a little more than 4 times you have 4.10s! Hope this helps!
Installing the speedometer gear will be super simple! All you have to do is jack up the car and then on the rear portion of the tranny there will be a place that needs the gear!
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
I support the MM Staff
Old May 22nd, 2007, 11:42 PM   #3
Sounds easy enough. Ill give it a try later on tonight.
Old May 22nd, 2007, 11:46 PM   #4
yeah man! I wish I would have bought a stang with gears in it already!
Old May 22nd, 2007, 11:49 PM   #5
Well I didnt really need the car. Its got some body problems but it runs and sounds GREAT!... But for 2,000 I couldnt pass it up. Work might be killing me but at least the moneys good.
Old May 22nd, 2007, 11:50 PM   #6
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
wait... your speedo doesn't work at all?
or it is not showing the correct mph?
Old May 22nd, 2007, 11:52 PM   #7
It doesnt work at all, There is no gear at the transmission. its not that the wrong gear is there. its just not one at all. the guy was working on replacing it when i bought it.
Old May 22nd, 2007, 11:56 PM   #8
HMUSN's Avatar
19.83 @ 12mph
ah ok.
just checkin to make sure the guy isn't bs ing you
Old May 23rd, 2007, 08:36 AM   #9
Casper98GT's Avatar
more than likely you are gonna need a white gear, because it ranges from 3.55-4.30's.
White99stang-
Damn i miss the good ole days, you know in 2005 when the site first started and everyone wasn't getting butt hurt over every little thing
Ford/Toyota tech.
93 LX, H/C/I + Vortech
Threads Similar to: Speedometer
speedometer Mike73 Modular Mustangs 4 October 27th, 2007 02:49 PM
Speedometer akatagyourit 2.3 Mustangs 2 September 15th, 2007 02:24 AM
Speedometer cdesha 96-98 6 August 15th, 2007 02:11 AM
Speedometer. Kmh to mph Timmano V6 Mustangs 7 May 4th, 2007 12:38 AM
Speedometer 88MustangGT 5.0 Mustangs 8 January 3rd, 2007 08:11 AM
