Proud American
Nitrous Questions
I am trying to help out droppedbass and well I dont know some of the answers.
here are the questions He got this kit: Here is one question Where will he tap into the fuel line to run to the fuel solinoid? Question 2: Because it didnt come with a relay switch, will this one work and how does it exactly work? when you switch the relay will it give power to the solinoids and then when he goes WOT will the solinoids open? Thanks I am sure that we will have more questions too!
anyone please help
ok im about to buy a nos relay to run a wire from my engage switch to the micro wot""wide oped throttle""..then from the wot to the relay..then from out of the relay a power from the battery goes to the relay and then a green wire goes to both and ground out the relay...am i missing anything??
oh and i have some kind of fuel thing if you can see it in the picture..i think he had it because he was going to put this on a a carb s10 v8..350 i think..i think i dont need it and i can hook it straight into my fuel pressure testing thing right?
the WOT switch will close the circuit and give power to the solenoids. run a fuel line from the schrader valve on the fuel rail to the fuel solenoid. If going over a 100-125 shot you might need to either get a stand alone fuel system or get a bigger fuel pump
1986 Mustang GT t-top time piece! |
RLY SRS
DO you ahve the shrader valve on the passenger side of the fuel rail? that is where you can pull fuel...Or you can use a fuel accumulator and that way you dont run a chance of getting a lean spike...
Just buy an actual WOT = Wide Open Throttle switch that goes on the Throttle body... |
yeah there is a shrader on his fuel rail.
And whats wrong with using a WOT switch ? easy to mount and very safe.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
#8 | |
RLY SRS
yeah i do have the micro wot switch..i dont have the relay..and im missing the line that goes to the fual solenoid to the fuel rait thing..
call that dude and tell him its missing. You can get one for around $25 I think.
All I have ever used is a WOT switch. Never used any other switches, but I highly recommend them.
Threads Similar to: Nitrous Questions
| more nitrous questions | TTownZilla | 99-04 | 63 | September 7th, 2007 05:57 AM |
| nitrous questions | gtdan | 96-98 | 4 | August 27th, 2007 09:46 PM |
| NITROUS questions | rkloehn | 5.0 Mustangs | 5 | April 15th, 2007 11:48 AM |
| Nitrous questions | foxstang | 5.0 Mustangs | 21 | March 17th, 2007 12:10 PM |
| Nitrous questions | foxstang | 5.0 Mustangs | 16 | March 12th, 2007 10:29 PM |
