LinkBack (1) | Thread Tools |
#1
1997 Mustang GT
Groaning when Turning
Ok, so I am completely at a loss on what to do here. I have a 97 Mustang GT and when I bought it there was an aftermarket suspension system on it and things worked great for a while. But in the past month she groans when I turn even if its a small turn. It is an incredibly annoying thing because her exhaust sounds great but that groaning makes her sound like a piece of junk... You guys have any idea what it could be and how I could fix it? Its a low pitched groan
Abyssinian of AX
'02 Saleen
19.34@42.259
The first thing I would do is confirm that all the suspension joints are greased
![]() Have you given your car a lube job? There are many rubber bushings, that when dry, will squeak and creak like a big dog. Take it in to your local shoppe and have them give it a once over. Non-lubed bushings will not only make noise, but wear out faster causing additional expenses over time. Jazzer
Hooo Ha Ha
check your power steering fluid level
![]() 410rwhp 520rwtq @ 12.9 psi |
Abyssinian of AX
'02 Saleen
19.34@42.259
oooooohhhh..... forgot about that one
That is a VERY common issue on ye ol' Ferds
Balljoints will groan when they're on their way out, too.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
As do wheel bearings as well.
![]() Sig by Tricep |
Priest of the Car Gods
My bet's the power steering fluid.
1997 Mustang GT
Ok, thanks guys. My friend and I think it may be the bushings. But I will check the power steering fluid (Easy Fix) and the other things mentioned and hopefully get it figured out!!! Lol now onto the more expensive fixes... (My Brembo Brakes need new pads and lines.. sigh ouch)
1997 Mustang GT
Alright... So I did the power steering fluid. And that has not fixed the problem. Since that isn't the problem what else could it be? And what is the most likely to be the problem
What do you mean by you "did" the power steering fluid?
Did you just check it (and if so did you do it with the car running? 'cause that's how you're supposed to...)? Or did you do a flush of the system and replace all the burnt nasty fluid with fresh?
Bringing Yellow Back
jack it up a nd grease it like jazzer said
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
1998 Mustang GT
probably a wheel bearing. If you driving try to coast so your exhaust isnt too loud then turn the wheel back and forth ever so slightly so you car zig zags a little. If it groans like a wooo woooo wooo everytime you start to turn its most likey the wheel bearing. ball joints and other joints usually squeak not groan. other than the wheel bearing your power steering is at fault. Check the fluid and make sure theres no air in the system. Your pump might be starting to fail
pi swapped and dropped sn95 |
1997 Mustang GT
It is a the "woo woo" sound. lol
Ya it isn't a squeaking noise not even close it just a low pitch sound like you described. So since it is that low pitch noise. What exactly do I need to get done? I know the two were mentioned... But honestly I am not sure how to fix it... |
Is it only making this noise when the car is moving, or is the noise present if you turn the wheel while stationary? That will help narrow it down.
1997 Mustang GT
I believe it is only when moving I haven't actually checked that. But I believe it is when I am moving...
If it's only when moving, then it's a fair bet that it's a wheel bearing.
1997 Mustang GT
sigh... cost on that? The real kicker is x pipe has gone out and my brembo pads are done... :-) that's an easy 300... So any idea of what the cost for that will be and how hard it will be to fix?
The joys of performance car in college :-D |
A front hub/wheel bearing assembly should be around $50. It isn't a difficult job.
1997 Mustang GT
Cool thnx
13.64@101mph
very simple..remove the brakes. pull the dust cap off..break the 30mm spindle nut..and slides right off...slide on (after applying wheel bearing grease to spindle shaft) then tighten down hub and put everything back together lol
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/233966-groaning-when-turning.html
| Thread Groaning frontend when turning steering wheel | LX Forums | Dodge Charger Challenger Magnum | SRT8 | Chrysler 300 Forum | BoardReader | This thread | Refback | October 9th, 2011 10:58 AM | |
Threads Similar to: Groaning when Turning
| Groaning coming from passenger side | XectriK | 99-04 | 13 | February 23rd, 2011 08:58 AM |
| groaning in backend after long drive.... | R3dFyre02 | 99-04 | 13 | February 11th, 2010 10:40 AM |
| groaning sound coming from brakes | dgt_mustang | V6 Mustangs | 7 | April 2nd, 2008 04:54 PM |
| Groaning/vibration after hard take off... RPM dependant... Help? :) | R3dFyre02 | 99-04 | 7 | January 5th, 2008 05:38 AM |
| moaning and groaning | PiggySmallz | 2005 - 2010 | 21 | October 2nd, 2007 03:09 PM |
