removing rear bumper cover - Forums at Modded Mustangs
post #1 of 7 Old September 22nd, 2011, 05:42 PM Thread Starter
devildog0311's Avatar
Can anyone tell me the steps to removing the rear bumper cover on a 96
devildog0311 is offline
post #2 of 7 Old September 23rd, 2011, 06:06 PM
Rollin' 18/ pushin' 2
97S281's Avatar
iTrader: 18 reviews
1. Open the trunk and remove the tail lights. The nuts are recessed, you will see them if you look for them.
2. pull out the interior side trim panels from the trunk. There are two nuts on each side that hold on a set of brackets that the bumper cover is attached to.
3. remove the center section of your trunk panel and remove the nuts attached to the center bumper bracket.
4. check your wheel wells. There should be two screws on eack side that attach the rear bumper to the wheel well.
5. Pop the sides off from the wheel wells.
6. pull straight back on the bumper. This can go easy or it can be difficult. Sometimes the center bracket gets caught on the slots for the bolts to go through the car. your bumper should now be off.
TIP: If reinstalling a new bumper you will get a better fit on the sides if you don't rivet the side brackets back onto the new bumper. Instead, sandwich the lip that would rivet to the bracket between the body and the bracket and it will fit much tighter to the car.
MODS IN GARAGE
All SVO'D UP
97S281 is offline
post #3 of 7 Old September 23rd, 2011, 06:10 PM Thread Starter
Thanks man, what about those things on underneath the bumper, I think they are pull tabs?
post #4 of 7 Old September 24th, 2011, 12:02 PM
97S281's Avatar
iTrader: 18 reviews
Pic?
MODS IN GARAGE
All SVO'D UP
97S281 is offline
post #5 of 7 Old September 24th, 2011, 02:37 PM
if u are talking about the push pins then simply get in behind them and pull them out if you brake it you should be able to get one from an auto store
c-for is offline
post #6 of 7 Old September 25th, 2011, 05:30 AM
marq.fcb's Avatar
Send a message via MSN to marq.fcb
marq.fcb is offline
post #7 of 7 Old September 26th, 2011, 05:03 AM Thread Starter
Originally Posted by marq.fcb View Post
Thanks bro, that helped a ton, Give me the link to more of your videos, I am actually about to paint my car and I can use the help on taking off the front bumper as well.
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/234111-removing-rear-bumper-cover.html
removing rear bumper cover This thread Refback March 16th, 2014 12:17 AM
removing rear bumper cover This thread Refback March 12th, 2014 12:24 AM
