did PI Intake swap... now running rough, please help
LinkBack (1) Thread Tools
Old October 2nd, 2011, 12:38 PM   1 links from elsewhere to this Post. Click to view. #1
delgadog's Avatar
1997 Mustang GT
None yet...
delgadog is on a distinguished road
i switched out the PI intake yesterday, let everything sit over night. rechecked everything this morning, found an injector O-ring went bad so i replaced it. turned it back on and took her for a 2 mile spin. the entire time the car ran really rough. liek the spark plugs were bad or something, but i made sure all the boots were on tightly. i parked her and opened the hood and a little bit of coolant and a hissing sound was comming from the rear drivers side of the intake... idk if its lack of RTV, or if its not bolted down enough... any thoughts... i REALLY DON'T want to tear this sucker down again... i'm out of town at my parents house and i have to be at work tomorrow. any insight would be great!! thank you!!
95 GT - nothing stock on her R.I.P.
97 GT - New hotness: CAI, 70mm TB, TB Plennum, PI Intake
comming soon: PI H/C, shorty headers, o/r x, lower car, sub frames, cc plates, torque box kit, rear U/L control arms, NO2 kit 100 shot.
Old October 2nd, 2011, 12:44 PM   #2
delgadog's Avatar
1997 Mustang GT
None yet...
btw, i changed plugs about a month or two ago...
Old October 2nd, 2011, 12:51 PM   #3
Green4.6's Avatar
1996 Mustang Gt
9.9033@70.85 1/8 in rain(Stock)
Green4.6 is on a distinguished road
It's probably a lack of rtv, you could have also got coolant on a spark plug.
Pacific Green 96 Gt
Old October 2nd, 2011, 01:19 PM   #4
delgadog's Avatar
1997 Mustang GT
None yet...
well, the pasenger side looks great, no coolant, plugs seem fine. its only the drivers side. is there anyway to just redo the drivers side? and will i have to buy another set of gaskets?
Old October 2nd, 2011, 03:53 PM   #5
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Gaskets are fine but you do have to pull the intake up and re rtv it. Also you could have fluid coolant in that rear spark plug hole so i would check that.
Also check for a vacum leak..that will normally cause the car to run like shit
410rwhp 520rwtq @ 12.9 psi
Old October 2nd, 2011, 06:14 PM   #6
delgadog's Avatar
1997 Mustang GT
None yet...
thanks shart bait, i ended up re RTV it. but unfortunately, i can't let it sit over night, it'll only have about 4 hours of cure time... so i'm concerned that it might not cure all the way.... is 4 hours of cure time ok?? i have a 4 hour drive time later on tonight, will it be ok?
Old October 2nd, 2011, 06:22 PM   #7
14.92@ 86
darkmajesty is on a distinguished road
I haven't done the swap yet, but both guides say to let it sit overnight to fully cure. I haven't really seen an rtv that doesn't need to sit 24 hours.. but I've only just used that autozone rtv and its worked great. I just figured I would chime in.. Im not for sure if I would drive it or not, but looks like your situation won't allow you not too.
PP 75MM TB/PP Upper Plenum/Mac Prochamber/ Mac Flowpath Catback/JLT RAI/BBK UDP/SCT Race Tune/FRPP 4.10's/ 1/2 PI Swap/AM Short Shifter
Old October 2nd, 2011, 07:05 PM   #8
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
If you drive it im gonna find you on side the road and kill you lol. dont drive that unless you want to be stuck .
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old October 2nd, 2011, 08:17 PM   #9
delgadog's Avatar
1997 Mustang GT
None yet...
well diamond, i have no choice, i'm at my parents house visiting and did the swap yesterday, but had to redo it today... yea, it sucks... i let it sit over night and i didn't rtv it all that well the first time... i started it up and so far so good, no leaks, nothing.
Old October 2nd, 2011, 10:08 PM   #10
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
WAIT...you have no choice..give it propper cure time and be shur to use more than you think you will need...
Old October 2nd, 2011, 10:11 PM   #11
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
Well good luck man i wouldnt do it lol.
Old October 2nd, 2011, 10:15 PM   #12
14.92@ 86
Let us know if you made it and lady luck was on your side tonight.
Old October 2nd, 2011, 10:40 PM   #13
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
You should be fine, just take it easy, i used it on my water pump and drove it 20 minutes later.
Old October 3rd, 2011, 01:14 AM   #14
devildog0311's Avatar
Black 96 Gt
devildog0311 is on a distinguished road
Sorry guys can someone tell me what rtv means?
Old October 3rd, 2011, 01:23 AM   #15
Green4.6's Avatar
1996 Mustang Gt
Lol not sure what it means exactly but its silicone.
Pacific Green 96 Gt
Old October 3rd, 2011, 01:23 AM   #16
1992 Mustang GT
dont know yet
96paxtonstang is on a distinguished road
Room Temperature Vulcanizing (Silicone)
Sent from my Autoguide iPhone app
______________
Mods:
Paxton Novi 2000 @10psi
3.73 gears
255lph fuel pump
Lucas 42# injectors
Trick Flow 75mm upper intake
Trick Flow 75mm throttle body
Diablo "MAFia"
Dyno tuned by Force Fed performance Sacramento Ca
Old October 3rd, 2011, 02:26 AM   #17
Black 96 Gt
Thanks
Old October 3rd, 2011, 07:52 AM   #18
delgadog's Avatar
1997 Mustang GT
None yet...
well, a little update from last night. car did fine, no leaks, i don't hear hissing, car isn't full of coolant. HOWEVER... my check engine light is blinking and there is MAJOR hesitation and ALOT of back fire (popping) from my exhaust... so i'm thinking my plugs and wires are fouled, i'm just going to change the wires seeing that the plugs where changed a few months ago, i think i'm just going to clean up the plugs with a rag and new wires. if anyone has any insight as to the check engine light flashing and those symtoms that would be awesome! and thanks for your concern guys!
Old October 3rd, 2011, 08:57 AM   #19
1996 Mustang GT Vert
Blower Head is on a distinguished road
The flashing check engine light means you have a serious misfire. It will destroy your converters if driven like that for very long. If you can get the codes pulled it will tell you which cylinder is misfiring. Glad to hear the redo of the RTV seems to be holding. Never was thrilled with the idea of using that method, but it seems to work for most people.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's
Old October 3rd, 2011, 09:21 AM   #20
delgadog's Avatar
1997 Mustang GT
None yet...
yea, i know, i'm not a big fan of rtv either, however, the PI intake was a good deal and its an upgrade so i went for it. and i rtv the crap out of it too for good measure.lol.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/235146-did-pi-intake-swap-now-running-rough-please-help.html
Intake Replaced - Running Lumpy This thread Refback February 23rd, 2012 03:18 AM
Threads Similar to: did PI Intake swap... now running rough, please help
2.3 N/A Running Rough 1993MustangNotch 2.3 Mustangs 3 June 27th, 2011 08:27 PM
car running like crap after pi intake swap... firechicken93 96-98 11 June 21st, 2011 08:43 AM
Why is my car running rough? Red83GT 5.0 Mustangs 1 June 7th, 2010 05:41 AM
My car is running rough 99BlackBetty 99-04 6 January 6th, 2009 01:49 PM
car running rough 01 gt johnr2001 99-04 20 March 20th, 2008 06:31 PM
