1997 Pacific Green Cobra
14.80 No traction
Cam advancing.
Is their a write up on this somewhere around here for our motors . Im trying to learn how this works . cause i want to use adjustable crank gears and i saw that they advanced the drives side by 8 degrees and retard the passenger by 4 ... wtf .. i don't get it honestly . Just wondering if there is somewhere that explains all this. Thanks a million
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
14.80 No traction
So ill assume no one knows. cause i honestly can't find it altho i have seen it before
13.64@101mph
Modularheadshop - MHS
Top right hand corner..articles and faqs...scroll down to how to intall/degree with tfs adj crank sprockets. Done
4v Know-it-all
You can use the TFS crank gears to advance or retard the cams. They have 9 keyways and with 2 deg increments (0, 2, 4,6,8 deg). Each side is advanced/retarded individually and both sides have the same amount of adjustment.
13.64@101mph
^ could just let him read the link I set...since google doesn't exsist anymore
4v Know-it-all
14.80 No traction
Bumping my old topic. Few more questions on it. Is it on average that on these vehicles that the Passenger side stock gears are advanced some and that the drivers side is retarded by a little ? I have read this several times and figured i would ask some verification.
4v Know-it-all
No, and you won't know where they are unless you put a degree wheel on the engine
Rollin' 18/ pushin' 2
4v Know-it-all
Thats for a 2V, 4Vs are a totally different animal.
14.80 No traction
Haha yeah thanks . I was talking in reference to my current 2v motor . I did get most everything figured out at this point. i have a feeling that my passenger side may be too much advanced. I was planning on retarding both cam banks 2 degrees. Seems my upper end is just not there but the lower end is neck snapping.
I thought it was a question for a 2 Valve seeing as there is a tech section just for 4 valves.
14.80 No traction
it was lol .
Threads Similar to: Cam advancing.
| advancing timing | Everett | 99-04 | 6 | December 5th, 2010 10:57 PM |
| Would i feel advancing the timing/ is it worth it? | noyz25 | 5.0 Mustangs | 9 | April 20th, 2009 10:44 PM |
| stupid question, electronic cam advancing? | energiesource | 99-04 | 3 | June 23rd, 2008 01:16 PM |
| Advancing timing=how much power? | 8A_Honda | 5.0 Mustangs | 29 | September 9th, 2007 01:10 AM |
| advancing your timing | yellowstang98 | 96-98 | 1 | February 25th, 2007 04:56 PM |
