1998 Mustang GT
Urethane transmission mount for 1998 GT T45
Does anyone know where I can find one for a 1998? I can't find one anywhere!
Mods: Full Griggs suspension, Koni coilovers, Cobra brakes with SS lines, sub frame connectors, 3.73s, 5-speed swap, TR6's
1997 Pacific Green Cobra
14.80 No traction
From what i believe and research there is not one. and the only thing i hear would work is a cobra one but you have to modify it.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
1998 Mustang GT
Fail.
13.64@101mph
96-98 2v 5spd transmission mount/bushing..is FORD ONLY PART
1998 Mustang GT
Ya I know that one I have replaced it twice now. I want to get a Urethane one so I won't have to again.
13.64@101mph
no...like ITS THE ONLY ONE AVAILABLE. nobody makes a urethane one
1998 Mustang GT
Well that is just
1998 Mustang GT
I have read of some people modding a Cobra transmission mount to use to Urethane one. What exactly needs to be modded?
Its a different tranny mount youd have to change trans
1998 Mustang GT
FML. Guess I will have a local shop make me a solid mount or see if I can fab up one for a urethane one...
96 Mustang GT
B There 1 Day.
Tousley ford has the oem rubber tranny mounts for around 52$ shipped. Its a good price compared to everywhere else if u wanna do the oem again. Tousleys number is 1800-328-9552
![]() PI Manifold. FRPP. Steeda. Magnaflow. BBK. Accufab. RAM. MGW. MSD. NGK. NTK. Billet. J&M. Powerslot. Hawk. Walbro. Motul. Fel-Pro. Dupli-color. |
1989 LX Coupe
7.1@99mph
I have a urethane one on my 96...
![]() Its the fox one...what I did was notch out the x-member a little more toward the rear, got the bolts in then wrenched them down. Works great.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
13.64@101mph
OR JUST USE A STOCK REPLACEMENT they were good enough for factory and you'd never notice the different from a poly or rubber trans mount..not worth any work at all imho...
1998 Mustang GT
Well that is good that it is good for FACTORY but my car is far from factory and I don't like seeing my transmission bounce around all day long when I try and put some power down. Thanks for the tip Jugs...I mean NeverEnuff...sorry got distracted.
1998 Mustang GT
![]() iTrader: 2 reviews
your tranny shouldnt be bouncing around like that off of a stock tranny mount. Theres gotta be something else wrong there. There are plenty of guys putting down power with oem tranny mounts.
pi swapped and dropped sn95 |
1998 Mustang GT
Well I am going to try another one since I have no choice. Maybe some how the other one broke during 5speed swap.
8.7 1/8 mile
I think mine is a prothane or energy suspension. Believe it or not, I did notice a big difference when I put it in. The shifter doesn't move around at all now, feels like it should have felt from the factory, especially with my tri-ax.
I got it from my local performance shop, msperformanceonline.com. Hopefully this helps! |
#18 | |
8.7 1/8 mile
That makes no sense. Pretty much nothing on these cars was good enough from the factory, otherwise we wouldn't modify them like we do.
1998 Mustang GT
And it is the offset style mount?
8.7 1/8 mile
It's been a while since I put it on, I'll check and see. I don't think it is though.
Threads Similar to: Urethane transmission mount for 1998 GT T45
| Transmission Mount Alignment? | PhxMustang | 99-04 | 3 | July 22nd, 2011 10:22 PM |
| 1998 GT transmission mount | yamanx | 96-98 | 6 | May 9th, 2011 05:10 PM |
| T-45 transmission mount..... | whtstang97 | 96-98 | 0 | September 11th, 2009 03:27 PM |
| Transmission mount ! | k2boarder3187 | 96-98 | 1 | April 2nd, 2007 10:06 PM |
| transmission mount? | 97_4.6L_Stang | 96-98 | 7 | March 31st, 2007 01:19 AM |
