Sct for 96gt - Page 3
Old November 1st, 2011, 10:33 AM   #41
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
i might as well change them..i dont have any funny idle or anything but it cant hurt anything other than my pockets..and then its one less thing i have to worry about if something goes wrong.
Old November 1st, 2011, 09:31 PM   #42
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
Yeah i do suggest that lol. It will save you in the long run in gas milage.
Rockauto.com and make sure they say motorcraft
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old November 1st, 2011, 10:24 PM   #43
96 Mustang Gt
FLEX4.6 is on a distinguished road
Its like it gets shoved by superman for a split second but the rpms stay the same.
Old November 1st, 2011, 10:46 PM   #44
p4ndiamond's Avatar
14.80 No traction
is your TB cleaned. and it could be the MAF/ TPS sensor doing that. hard to tell without seeing it in person. First thing first is reset ECU by taking battery cables off. Thats always a quick easy check when low on time to look more. And cleaning the IAC
Old November 1st, 2011, 11:27 PM   #45
p4ndiamond's Avatar
14.80 No traction
When i think aobut it sounds like something is slipping if it feels faster but RPM the same... how are the rotors and clutch on it.. i mean i can only guess what you speak of lol.
Old November 2nd, 2011, 09:41 PM   #46
96 Mustang Gt
Transmission and clutch are 2 weeks old. Its lean causing it not mechanical. It does not do it at wot. Codes read all about o2 sensors and lean. It pulled up the rear 2 which are bank 1 sensor 2, and bank 2 sensor 2, which is none there. And bank 2 sensor 1 I believe. So I am goin to change the sensors. I put a can of seafoam in gas to clean injectors, I got some maf cleaner and I am goin to do that also.
Old November 3rd, 2011, 07:54 AM   #47
TooFast4theFUZZ
seafoam through the brakebooster untill it stall the car...wait 5min and keep turning it over untill it starts..and enjoy the smokeshow for awhille..at the sametime seafoam the gas to clean the fueal system..that shit does wonders..through the brake booster is the biggest help becuase it cleans your intake system,and after that clean your mafs with mafs spray since its like 5 dollars and 5 mins of work..
Old November 3rd, 2011, 08:38 AM   #48
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Using an incompressible liquid to stall an engine is a easy way to bend connecting rods. Seafoam (or water) won't hurt anything if poured in slowly, but I would not stall the engine with it.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old November 3rd, 2011, 10:54 AM   #49
p4ndiamond's Avatar
14.80 No traction
Dont bother changing the back you need to be changing the front. hte backs are insignificant to engine performance and fuel curve.
Old November 3rd, 2011, 03:03 PM   #50
96 Mustang Gt
I dont have backs...
Threads Similar to: Sct for 96gt
rx8 vs 96gt philly101 96-98 22 April 18th, 2012 05:54 PM
new here with a 96gt projectGT 96-98 7 March 20th, 2011 06:31 PM
96gt AC help! wicked96gt 96-98 18 August 9th, 2010 06:01 AM
96gt..help. jchr96gt 96-98 3 March 20th, 2009 05:27 PM
96GT Help please nHuman 96-98 3 January 31st, 2008 10:06 PM
