Camber Bolt Review?
Old October 26th, 2011, 01:27 PM   #1
Ruffellbaker's Avatar
1997 Mustang GT
Ruffellbaker is on a distinguished road
Camber Bolt Review?
My car is lowered and Im thinking about buying the camber bolts instead of the plates. $25 sounds alot better than $200.
Anyone using these bolts? Any problems?
PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune.
Old October 26th, 2011, 08:09 PM   #2
1998 Mustang GT
MustGT98allday will become famous soon enough
how low are you dropped. Because cam bolts will work (I have used them in the field numerous times) but they only do so much.
pi swapped and dropped sn95
Old October 26th, 2011, 08:50 PM   #3
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
Camber bolts are good for between 1°~1.5° and will not do the second "C" of which plates will do Caster is the second adjustment and can be a major improvement in cornering, if you're into it. Camber bolts are weaker than OEM bolts and therefore don't recommend them.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old October 27th, 2011, 07:48 PM   #4
1997 Mustang GT
Its not lowered all that much. Im not really into the Auto X thing so cornering isnt a big deal. I pretty much baby my car and even if I do get into it, its in a straight line. Im not even worried if the camber is perfect. Just wanna stop my tires from wearing so quickly.
Old October 27th, 2011, 08:07 PM   #5
Abyssinian of AX
'02 Saleen
19.34@42.259
One does not have to AX or race the car to put strain on these bolts They may be fine in your case, but have seen where too many experienced guys have seen them brake. I recommend you spend the extra money and get CC plates to allow better control over the alignment specs.
Jazzer
Old October 27th, 2011, 08:22 PM   #6
1998 Mustang GT
i second that. there are many out there new and used you can find for all sorts of prices.
Threads Similar to: Camber Bolt Review?
Camber bolt help? TCStang 2005 - 2010 5 August 27th, 2011 07:10 PM
Camber bolt torque Icestang05 2005 - 2010 2 July 29th, 2010 07:29 PM
Ford Racing 3 Bolt Camber Plates? 02MGT 99-04 1 March 19th, 2009 10:15 PM
Camber Bolt Install ??'s stanglifemike 2005 - 2010 6 December 29th, 2008 01:12 PM
HELP! SOHC 6 bolt crank/ cobra 8 bolt crank interchangability? the1968jeepthing 99-04 2 September 29th, 2008 11:39 PM
