need help from everyone who has installed a bumpsteer
Old October 27th, 2011, 10:16 PM   #1
1998 Mustang GT
MustGT98allday will become famous soon enough
so i have looked into a bump steer for a long time now. At one point I had the MM bumpsteer kit in my possession. I looked over the instructions and it seemed very difficult. Then i never got to install it and ran into financial difficulties and had to sell it. Now I want another one to install this winter. Now heres where i need the help
I looked it over and The instructions to MM's bumpsteer is pretty easy, however, they say if you have modified your front suspension at all you need to calculate your bumpsteer and correct it with the different spacers and such. Now I am lowered on sportlines with c/c plates. My question is has anyone just simply installed the kit as the instructions say for stock geometry and had no problems? because reading through all the steps to calculate bumpsteer seems very confusing to me.
so who has installed a bumpsteer, what kit did you use, and how are the results?
pi swapped and dropped sn95
Old October 27th, 2011, 11:04 PM   #2
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
I think the MM instructions are over-kill for the VAST amount of people that are installing these kits. Ideally, the steering rack should be level with the arms going from one side to the other. My own cars tie rods are at least 1" higher on each end... lol
They have been fine for 5+ years now with some bump-steer, but is completely managable.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old October 28th, 2011, 10:17 PM   #3
1998 Mustang GT
ya i didnt think it needed to be that in depth. I wish i didnt have to sell my new set i had but o well. i have all winter.
thanks jazzer
ps. if i get some i will most likely pm you for some help
Old October 30th, 2011, 06:11 PM   #4
Macunicorn's Avatar
Macunicorn will become famous soon enough
I wonder if the bumpsteer correction is noticeable when driving, or is just to correct the bumpsteer after changing the ride height.
Sig by Tricep
Old October 30th, 2011, 08:54 PM   #5
Abyssinian of AX
'02 Saleen
19.34@42.259
It has to do with changing the ride height and can be noticed when a sudden droop of suspension happens. Whether your car be lower or higher (better NOT be higher ) the arms become essentially "shorter" because the relative elevation between the steering rack and the spindle differs. The amount of difference creates bump-steer and is not usually much issue until one drops beyond 1.5" or so.
Jazzer
Old October 30th, 2011, 09:12 PM   #6
1998 Mustang GT
well im definitely below that. and right now i have to replace my tie rods every year. this is why im looking into a bump steer
Threads Similar to: need help from everyone who has installed a bumpsteer
No more bumpsteer 2VSouth 99-04 6 April 13th, 2011 06:38 PM
Anyone installed Steeda Bumpsteer with Steeda Springs YeloPony 99-04 3 January 6th, 2010 06:20 PM
Which Bumpsteer kit to go with? black88 5.0 Mustangs 7 January 23rd, 2009 11:39 AM
Is this Bumpsteer? bzeboymenz General Tech 15 February 2nd, 2008 02:39 PM
Is This Bumpsteer? bzeboymenz 99-04 5 December 16th, 2007 03:30 PM
