Stuck key, Need help
Old October 30th, 2011, 11:00 PM   #1
1996 Mustang gt
96red&blackstang is on a distinguished road
So i just replaced my heater core and i put everything back toghether; drove it to make sure everything was fine. after parking and turning the car off i tried to pull the key out and it didnt come out. the ignition does not want to turn all the way to take the key out. so i looked under the dash and messed with the black cylinder to see if the key would come out. no luck the key is still stuck. i saw 2 connections that weere loose so i pluged them back in, but i think i pluged it the wrong way now gauges dont work at all what happened, what can i do to fix this problem. can someone help me. i think those connection are part of the pats system. also i have a aftermarket alarm. would the people that did the alarm tooken off these wires and me being an idiot plugged it back in.
Old October 30th, 2011, 11:09 PM   #2
1998 Mustang GT Convert.
drakkhen20 is on a distinguished road
well if its an auto make sure its in park and check the sensor for that it might have went out. make sure your steering wheel isnt locked. its sounds more like a mechanical failure than a electronic one but you never can tell. thats the only thing i can think of. make sure you disconnect the battery so it doesnt run down being that its stuck in the on position.
Old October 30th, 2011, 11:44 PM   #3
1996 Mustang gt
car is indeed in park, also i have messed with the shifter moving it up and down. also moved the streening wheel. never had problems with the key at all never had it get stuck
Old October 30th, 2011, 11:51 PM   #4
hmm. strange man. wish i could more but thats all i can think about.
Old October 30th, 2011, 11:57 PM   #5
1996 Mustang gt
much appriciated. i just want to know if anyone else can explain why this happening. also can explain the problem with the guages.
Old October 31st, 2011, 12:39 AM   #6
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
Turn the wheel while removing the key...
Old October 31st, 2011, 03:32 AM   #7
1996 mustang GT
projectGT is on a distinguished road
This happened to me with a celica a while back. Remove the center piece around your automatic shifter and look for a connection by it. Once you've found a connection around the shifter, disconnect and connect it back and try your key. Like i said it was on a different car so the connection might be in a different area but same thing. Good luck.
Old October 31st, 2011, 11:57 AM   #8
1996 Mustang gt
im looking around the shifter and their is a cable going to it. the only time the cable moves is when i press the side button to shift.
Old October 31st, 2011, 11:58 AM   #9
1996 Mustang gt
also found two blown fuses that caused my guages to not work. replaced them now they work
Old October 31st, 2011, 01:06 PM   #10
1996 Mustang gt
well i finally fixed it. their is a little black cylinder near ur streering colum i took it off cleaned it out now my key comes out. i guessin the mechanism got jammed. kind of pissed that i had to miss work for this problem. hope this anyone else who runs into this problem
Old October 31st, 2011, 02:41 PM   #11
1989Gt.'s Avatar
1989 Mustang GT
Thats rediculous.
Threads Similar to: Stuck key, Need help
stuck between 2 for my next mod StutteringStang06 2005 - 2010 24 April 6th, 2010 10:33 PM
stuck again SWEET2KSTANG 99-04 30 December 11th, 2008 05:31 AM
Stuck on what to do next to my car... MustanG_guy17 The Clubhouse 41 December 2nd, 2008 12:06 AM
stuck SWEET2KSTANG 99-04 29 July 13th, 2008 11:57 PM
acc stuck on???? 2006greyGT 2005 - 2010 0 April 13th, 2008 05:16 PM
