Change of plans. PI mani and Cam results?
Old October 31st, 2011, 11:20 AM   #1
Ruffellbaker's Avatar
1997 Mustang GT
Ruffellbaker is on a distinguished road
I was going to wait to do a full PI head swap but Ive been thinking it over and Im going to go ahead and install my Intake and Cams and keep the npi heads on. Im gonna save to boost instead.
The only problem I have. The PI intake manifold I have was given to me for helping someone turbo their car. It has the plastic crossover and a small hairline crack in the rear that I have repaired. What will I have to do to make this work with my 2nd coolant temp sensor since I cannot tap the plastic?
Also anyone that has installed only the pi cam and intake and used an SCT tune, how much power would you say that you gained? Im not looking to see a huge gain. If I see 20hp Ill be more than satisfied.
PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune.
Old October 31st, 2011, 01:35 PM   #2
96 Mustang Gt
FLEX4.6 is on a distinguished road
I am subscribing to this. Im curious also.
Old October 31st, 2011, 02:43 PM   #3
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
If its cracked dont use it its only gonna be a matter of time before it opens it. Remember heat expands and cold contracts, not a good mix for plastic really.
Old October 31st, 2011, 03:04 PM   #4
1997 Mustang GT
I just read that I can take my aluminum crossover from my npi intake and swap it to my pi intake. Problem solved. The crack is sealed very well. I used a dremel tool to grind it and used plastic/heat/water epoxy to fill it. It was on my friends dads car for months before he ended up wrecking it.
Old October 31st, 2011, 04:19 PM   #5
1989Gt.'s Avatar
1989 Mustang GT
Seems like to much work instead of buying one off cl. They usually go for 50-100 bucks.
Old October 31st, 2011, 04:31 PM   #6
1997 Mustang GT
Ive been looking on craigslist for months and months. No one has anything in my area. Either way, free is better.
Old October 31st, 2011, 05:03 PM   #7
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
then hows this..i have a dorman aftermarket PI manifold..a bolt is broken in it but i used it like that for 2 years no problem..if ur Pi heads are all intact with rockers and all ille trade you my manifold for them...i wanna go PI head..
Old October 31st, 2011, 10:07 PM   #8
TooFast4theFUZZ
and btw, you will see some very nice gains exp with the tune, get the most aggressive tune for the trans,93 oct and 170 thermostat...thats alone over stock will make you say"ha,shoulda did that sooner...so easy.so nice gains"...
Old November 1st, 2011, 04:16 PM   #9
1997 Mustang GT
Im already running the 93 tune. My car is a 5spd.
Threads Similar to: Change of plans. PI mani and Cam results?
Change of Plans Scott2001GT 99-04 14 February 27th, 2010 12:12 AM
Change of plans DSG04GT 99-04 32 March 17th, 2008 11:56 PM
Change Of Plans... phebecates78 96-98 22 December 13th, 2007 11:48 AM
A change of plans for my 95' Snipe061 V6 Mustangs 2 April 10th, 2007 03:17 PM
Change In Plans itschristorres8 V6 Mustangs 89 October 19th, 2006 10:52 PM
