LinkBack (1) | Thread Tools |
#21 |
Traction...?
1996 GT/ 2008 GT Vert
Mine used to stall out at almost every stop, under WOT it would choke then start to scream. Upstreams control your air/fuel mixture.
#22 |
1998 gt
check for vacuum leaks around the pi intake.... i found that doing the swap if you dont use the adapter plates will cause leaks. But I could be wrong since others had success swaps with RTV... and check ur tb and intake piping..
vortech v1 strim intercooled with lots of goodies , 4.10s, built rear end, pi intake, 78mm bbk tb, SCT tuner, bassani with flowmaster 44, mega bite jr lca, J@M full length subframe connectors, tuned by AED. and more suspension mods
#23 |
Have tou figuredout the problem, I'm having similar problems
MM FOBRA CLUB MEMBER #1 |
#24 |
lol guarenteed if the o2 were bad it would throw a code .....you got a vacume leak, dirty maf, or u need a tune for the cams...
#25 |
1998 gt
agree on the o2. if u want spray brake cleaner around the intake manifold next to the injectors and plugs while its running. if u spray at a spot and hear a higher idle then theirs ur leak. found mines at the passenger side of intake next to last injector and drivers side by the power steering pump...
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/239855-erratic-idle-stalls.html
| Thread Rough idle and stalls | Forums at Modded Mustangs | BoardReader | This thread | Refback | April 5th, 2012 08:51 PM | |
Threads Similar to: Erratic Idle and stalls...
| Rough Idle and Erratic Voltage | 89Vert | 5.0 Mustangs | 5 | May 20th, 2011 11:18 PM |
| Erratic Idle | eplbabel | General Tech | 4 | December 26th, 2009 01:03 AM |
| Erratic Idle | 84MustangGT | 2.3 Mustangs | 9 | December 10th, 2009 09:03 PM |
| erratic idle still.... | Toph6888 | V6 Mustangs | 8 | March 30th, 2008 09:29 PM |
| Erratic RPM in Idle | mechwife | General Tech | 7 | April 9th, 2007 01:10 AM |
