Erratic Idle and stalls...
LinkBack (1) Thread Tools
Old November 18th, 2011, 09:46 PM   1 links from elsewhere to this Post. Click to view. #1
Doggins's Avatar
Doggins is on a distinguished road
Hey yall,
So i'm having a little some trouble hunting down this throttle problem. The car is acting strange at idle in that it will go up and down between like 200-800 rpms getting worse and worse until it stalls on the low side. Also, at low amounts of throttle the car is hanging and when i drop my foot past what i imagine is WOT the car suddenly lurches and gets all its power back...weird haha...when its decelerating with the car in gear i hear like a sucking sound from like 2200 rpms to 1300. wtf.
I've already replaced the TPS and the IAC. I've searched for a vacuum leak from the throttle body hoses but cant seem to find one. Any ideas?
I have an SCT scanner so i can run a data log, only problem is i have no idea what i would be looking for as i just bought the thing and am still trying to understand all the parameters.
Heres a list of mods just in case:
Full pi swap to include the intake.
Heads were ported prior to the swap
Reground pi cams
BBK shorty headers
All the bolt ons (accufab plenum, 70mm PP TB, JLT cai, udp, etc.)
Old November 18th, 2011, 10:45 PM   #2
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
o2 sensors will cause that, ask me how i know.
Old November 18th, 2011, 11:02 PM   #3
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
id say mafs is dirty or shot..
Old November 18th, 2011, 11:04 PM   #4
Doggins's Avatar
is there any way to test these before replacing them, especially o2 sensors, they are a bit pricey i think?
Old November 18th, 2011, 11:07 PM   #5
Traction...?
1996 GT's Avatar
Showing a check engine light? If so get your self a code reader.
Old November 19th, 2011, 10:14 AM   #6
Doggins's Avatar
no check engine light haha
Old November 19th, 2011, 10:27 AM   #7
bigjohnstud4200's Avatar
2000 GT 'vert
bigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura about
O2 Sensors are about $40 a piece on rockauto for motorcraft. How many miles?
"...but don't say my car's topless, say the titties is out"
Nas
Originally Posted by thrashersonmomma09 View Post
( member as in person not as in cock although i do love cock)
Old November 19th, 2011, 10:30 AM   #8
Doggins's Avatar
not sure if they are original, but if they are around 130,000
Old November 19th, 2011, 12:32 PM   #9
Traction...?
1996 GT's Avatar
^This, i did two up stream ones to my door for 86$ taxes in.
Old November 19th, 2011, 04:53 PM   #10
TooFast4theFUZZ
try atleast cleaning your mafs with mafs spray..its 7 bucks at any autoparts store..
Old November 19th, 2011, 06:17 PM   #11
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Well aftermarket cams can cause a rough idle and for it to stall.
Have you had a custom tune made yet?
410rwhp 520rwtq @ 12.9 psi
Old November 19th, 2011, 08:36 PM   #12
1998 Mustang GT Convert.
drakkhen20 is on a distinguished road
vacum leak. check your hoses and intake tube. the up and down idle is called "searching". that means the MAF sensor is going back and forth searching for the right efficient reading to idle steady. go clean it as suggested and see what happens and check your hoses. also consider the two up-stream o2s. its the very first o2s the are before the cats closest to the exhaust manifold/header. is the engine completely stock ? what after market parts do you have installed or recently installed?
Old November 20th, 2011, 03:11 AM   #13
Doggins's Avatar
Will clean maf tomorrow...is there anyway to tell via the sct datalogger if the o2s or the maf are bad? As for mods I listed the major ones in the first post....no recently installed as of this problem.
Old November 20th, 2011, 10:14 AM   #14
TooFast4theFUZZ
usually if an o2 sensor is bad or going bad it throws a engine code..just my experiance..just get that mafs spray cleaner and clean the mafs as well as you iac, its only 2 bolts to remove the iac, make shur to clean that spring very well in it, i even used grease cutter to bust through that shit in it.
Old November 20th, 2011, 12:39 PM   #15
you might need a tune man. or a new tune. trace your vacum lines, you might have one on backwards. your idle air control vavle might be a calprit to consider also.
Old November 20th, 2011, 05:21 PM   #16
Doggins's Avatar
Cleaned the maf today...no change. The IAC and the TPS are brand new as of last week. the car is hesitating as i bring the pedal down and then when it hits WOT it surges forward. Then when i come to a stop the idle starts pacing and bottoms out stalling the car....no check engine lights either....lol im lost
Old November 20th, 2011, 05:39 PM   #17
Traction...?
1996 GT's Avatar
This^
Although check behind the dash, for all you know your CEL bulb may be burnt out or removed due to the person owning before you getting sick of looking at the light.
Old November 20th, 2011, 05:43 PM   #18
Doggins's Avatar
IAC is brand new so its clean...also i have an sct code reader and im not showing any new codes, i am showing lean on bank 2 and rich on bank 2 though not sure if they are old or new codes..if it was a bad o2 sensor its a different code right?
Old November 20th, 2011, 06:25 PM   #19
Traction...?
1996 GT's Avatar
Thats an o2 sensor code bud.
Old November 20th, 2011, 06:54 PM   #20
Doggins's Avatar
I thought those codes were base don the trim being out of whack...i.e. i need a new tune, no that the o2 sensors have crapped out. This problem with the idle surge at WOT and stalling out when stopped is fairly new. Ill try replacing the o2s either tommorow or some time next week.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/239855-erratic-idle-stalls.html
Thread Rough idle and stalls | Forums at Modded Mustangs | BoardReader This thread Refback April 5th, 2012 08:51 PM
Threads Similar to: Erratic Idle and stalls...
Rough Idle and Erratic Voltage 89Vert 5.0 Mustangs 5 May 20th, 2011 11:18 PM
Erratic Idle eplbabel General Tech 4 December 26th, 2009 01:03 AM
Erratic Idle 84MustangGT 2.3 Mustangs 9 December 10th, 2009 09:03 PM
erratic idle still.... Toph6888 V6 Mustangs 8 March 30th, 2008 09:29 PM
Erratic RPM in Idle mechwife General Tech 7 April 9th, 2007 01:10 AM
