Real bad miss miss miss miss etc
98 GT Auto. Under heavy acceleration it constantly and quickly misses like crazy. Under normal driving conditions or WOT its just fine. Maybe a little miss at WOT, but real real real bad under other heavy throttle. Perfect at normail driving. Normal driving i keep rpms under 2200, most time at or under 2000. Plugs are motorcraft coppers with maybe 3k on them. I think engine is stock except PO put on a WAI with cone filter under hood, not infender. I have a perm installed fuel pressure guage. Car starts perfect, idles perfect, cruises perfect, gets 22mpg plus with 75%HWY. Could the intake cause this?
No vac leaks either, no codes. Has motorcraft wires.They "look"good, no sparks from them in the dark. Dont know age or maybe originals,CAr has 132k on it. Suggestion?
1998 GT. Headers with catless X-pipe into flowmasters. CAI. Cobra wheels 17x9 with 245/40's and 17x10.5 with 275/40's. 04 GT leather interior.
Hooo Ha Ha
check for water in the spark plug holes...check them all
![]() 410rwhp 520rwtq @ 12.9 psi |
Actually did that yesterday when i pulled plugs to check what they looked like, since they only have a couple thousand on them. The last 4 wks car has been DD with about 60miles a day with 40 or so being all hwy cruise at 60-65.
Hooo Ha Ha
Maybe you have a bad coil pack?
You said its fine at WOT but it misses at heavy part throttle?
Traction...?
1996 GT/ 2008 GT Vert
Coil pack might be heating up to much at WOT?
Just an idea.
Yes. It misses bad under heavy throttle like half to almost wot. Will go away if I floor it. Or its fine at normal driving.
1996 Mustang GT Vert
![]() iTrader: 1 reviews
If you can get the codes read by a scan tool that can check pending codes that might give you an idea what cylinder or cylinders are involved. Pending codes will show up without turning on the cel.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's |
98 mustang gt 4.6
Mine did that and didn't throw any codes it turned out to be plug wires. I just replaced stock ignition with ngk coils and wires and it went away.
There are no codes or pending codes stored. Think ill change the wires. Has motorcraft on it, but no idea how old they are. They look good and clean. But no idea on age. Maybe just wore out? Looks like one of the coil packs is a parts store. One has motorcraft on it, one doesn't.
98 mustang gt 4.6
It's more then likely the wires. Mine was doing it when I went over half throttle or on a fast take off. I changed plugs and still did it so just ordered wires and coil packs and it stopped
Going to pick up a set of good wires. What do you guys recommend. Anythuing better than the motorcraft? Saw some like 8.8MM wires on ebay. Suggestions?
Probably be a little bit before i do it. We are getting snow now. Besides not having a garage to do it in, its no longer DD till spring.
Traction...?
I've heard good things about Taylor, but i'm personally ordering myself a set of oem motorcraft wires this week.
Threads Similar to: Real bad miss miss miss miss etc
| I miss the WC | SlowNorth | The Clubhouse | 6 | July 14th, 2010 08:34 PM |
| carbed H/C/I 302 miss/sputter below 2k, and miss at 5k+ | Silversixspeed | 5.0 Mustangs | 1 | August 13th, 2009 09:54 PM |
| why does MM miss me? | Bandit | V6 Mustangs | 16 | April 14th, 2008 12:18 AM |
| The Real Miss America! | WAR-PARTY | The Clubhouse | 17 | November 9th, 2007 11:34 PM |
