1998 Mustang GT
![]() iTrader: 2 reviews
radiator cover
so everytime i look at my engine bay i notice my radiator cover doesnt look like it fits. so if people could please post a pic of how theirs fits that would be great. i feel like mine is wayy too short and i have a pic to show you what i mean.
the red circles i feel like should line up with were i put the red x's.
pi swapped and dropped sn95 |
Rollin' 18/ pushin' 2
looks like you may have had an aftermarket header panel installed at some point and it wasn't properly drilled. I would just drill out two holes in it and secure the cover properly with some push pins.
^^^ im with dummy. Front end collision?
MM FOBRA CLUB MEMBER #1 |
1998 Mustang GT
yes. the car was in a collision and the header panel was replaced. i could drill the panel and put two push pins but im still wondering why it doesnt fit. further things about it are i cannot put the pushpin in on the top right side because the cover wont stay down and the hood prop cant be put into its clip. so is my radiator cover ok and i have the wrong header panel? so replacing that would fix it?
After accidents, who knows just because everything was replaced doesnt mean things will be perfect again.
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
![]() iTrader: 1 reviews
^ yaaaa.metal bends.
If they used a cheap ebay header panel it usually isn't going to line up perfectly. I used one in the past. It was attractive because it was only $11. In the end it fit like you would expect an $11 part to fit and I ended up having to shave some off and drill new holes as well.
You can replace it with a factory one and see if that improves things or you could just drill new holes, use push pins and get some hood shocks so you can just remove the prop rod. You are going to spend about the same either way.
1998 Mustang GT
ok. well does anyone have a pic of theirs i can compare with cuz i dont even know what it looks like normally
1996 mustang GT
1996 mustang GT
Sorry its a bit messy around
1998 Mustang GT
thats ok. it looks like yours fits and the pins on yours lines up where as on mine the pins are supposed to go where the circles are but its no where near the holes where i put the rx's. i might try to find a junk yard one maybe it will be better
Threads Similar to: radiator cover
| Radiator Cover | bullitt1680 | 99-04 | 11 | February 4th, 2011 10:47 AM |
| 99-04 Radiator Cover | 98stangv6 | V6 Mustangs | 0 | March 12th, 2008 04:18 PM |
