oil pressure at. idle - Page 4
Old December 10th, 2011, 07:32 PM   #61
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
Another quick question is i was using a normal pressure gauge rated to 200psi would this be ok it wasnt liquid filled or anything. Im not sure if that will have a different reading tho.
MM FOBRA CLUB MEMBER #1
Old December 11th, 2011, 06:47 PM   #62
1989Gt.'s Avatar
1989 Mustang GT
Originally Posted by MustangMatt96GT View Post
Stop driving the car, pull the engine out and put new bearings in it...
Did you check clearances when you built it?
I just replaced and rebuilt my engine....
Old December 12th, 2011, 08:26 AM   #63
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Originally Posted by 1989Gt. View Post
where could i be losing it?
A bearing that is out of tolerance, a missing plug on any of the oil galleys, a bad spring in the oil pump, etc.
Gauges are liquid filled just to dampen vibration. It may slow the needle slightly, but it doesn't have a great effect on accuracy here, and it isn't an issue in this case.
I know it isn't what you want to hear, but something isn't right inside your engine. I'd highly recommend tearing it down and finding the issue before it starts making shavings out of the bearings.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old December 12th, 2011, 03:40 PM   #64
1989Gt.'s Avatar
1989 Mustang GT
Ok i understand what your saying im going to be taking the cover off cause i dont think its any of my bottom end bearings because all my tolerances were good. I replaced my pump too could something be bleeding the pressure at all?
Old December 12th, 2011, 03:44 PM   #65
Tang Stang's Avatar
You didn't use plastigage to determine your tolerances, did you? As far as what could cause the loss of pressure, I mentioned the possible causes in my previous post.
Old December 12th, 2011, 06:10 PM   #66
1989Gt.'s Avatar
1989 Mustang GT
No plasigauge lol No no a buddy of my dads put this together with me and i cant rememher off hand what it was exactly but they were all pretty much matching identically i know that.
I know they were all tight. I really doubt its the bottom end tho its not making a dang sound i was thinking would my tension-ers be bleeding off pressure?
Old December 13th, 2011, 08:46 AM   #67
Tang Stang's Avatar
I can't see the tensioners being the culprit, unless the bolts attaching them to the block weren't torqued to spec. If the bearing tolerances were indeed within spec, then I'd lean towards a missing oil galley plug or an issue with the oil pump. Which oil pump did you go with?
Old December 13th, 2011, 03:18 PM   #68
1989Gt.'s Avatar
1989 Mustang GT
I went with the ford racing high volume cobra pump, Where are the plugs at? What about the heads somewhere in there could i be leaking or something?
Threads Similar to: oil pressure at. idle
weird idle after pressure wash Chris951 5.0 Mustangs 22 August 25th, 2009 02:05 PM
Idle Vacuum and fuel pressure NDblackstang 2005 - 2010 17 September 1st, 2008 01:04 PM
(04 Mach I) Normal Warm Idle oil pressure? NewSchool 4V / SVT 1 July 14th, 2008 07:34 PM
oil pressure to low at idle?? jasons_98gt 96-98 9 July 1st, 2008 11:03 PM
