oil pressure at. idle
Old November 28th, 2011, 09:39 PM   #1
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
So today after 50 miles of driving my new engine I'm rolling up yo a light and I notice my pressure guage is low so I rev and it shoots to normal, now its been doing this all day.
Been fine up untill now I'm worried
Side note. The car wants to die at stop lights too could I be idling to low?
This is only ay idle so it scares me
MM FOBRA CLUB MEMBER #1
Old November 28th, 2011, 09:41 PM   #2
iPoopke Regular
2004 Mustang
iPAPKE will become famous soon enoughiPAPKE will become famous soon enough
Does it do it when you stop, could ave low oil
Old November 28th, 2011, 10:02 PM   #3
1989Gt.'s Avatar
1989 Mustang GT
Yea when I'm sitting still
would that be a symptom
Old November 29th, 2011, 10:13 AM   #4
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
well my 1st guess would be your oil pump...does your Tbody have a throttle screw you can adjust?
Old November 29th, 2011, 10:19 AM   #5
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
What rpm are you idling at, and what oil pressure are you seeing at idle?
Do not attempt to adjust idle rpm by messing with that screw.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old November 29th, 2011, 01:02 PM   #6
TooFast4theFUZZ
i never have but i did on my old honda..doesnt the screw just set the tps abit to run up or decrease the rpms based on the posistion on the tps? or open or close the throttlebody blade to allow or decrease airflow to adjust the idle?
Old November 29th, 2011, 01:15 PM   #7
Tang Stang's Avatar
The TPS "latches" when you first turn the key to "ON", so no. However, it needs to still be within range. Just remember that idle speed is adjusted in the EEC, not by the throttle body stop screw.
Old November 29th, 2011, 01:15 PM   #8
1989Gt.'s Avatar
1989 Mustang GT
This is hard to answer because when its running normal its usually 700 or so. But like i said when im coming to a stop it surges a bit then turns off. But anywhere between 500-900 on surging. Just sits at low.
Old November 29th, 2011, 01:36 PM   #9
Tang Stang's Avatar
When it's idling steady at 700 rpm, what is the oil pressure? If by "sits at low", you mean you're using the factory gauge, then it's time to get a real oil pressure gauge. The factory gauge is just a 7psi on/off switch.
Also, what oil viscosity are you using? This is on your 4V swapped car, right? Have you tuned the car for whatever you've done to it?
Old November 29th, 2011, 02:15 PM   #10
1989Gt.'s Avatar
1989 Mustang GT
Ok so i went out this morning checked the oil it was a little low, so i put about 3/4ths a quart in Turned it on, When the car warmed up went and pulled the iac valve it wanted to die so i know thats good,
Then i checked the voltage at the battery with the car running it was around 13v. So im pretty sure that was good.
Then i let the car idle warm and my freaking tach isnt working i got one of those tachs you have to tap the guage face and this time it wouldnt freaking move (cold maybe?!)
So i couldnt tell what she was idleing at but it was flickering between nor"ma"l and low oil pressure so before the " "normal.
Old November 29th, 2011, 02:17 PM   #11
1989Gt.'s Avatar
1989 Mustang GT
Checked ford tsb and it said for initial start up use 5w-20 So i went with that.
I have not tuned the car yet no. But everything and i mean everything in the bottom end is new, not used Brand new.
Havent had an issue for the first 50 miles ive been driving it till yesterday its not making any funny noises either. But i think your right i need to get a oil pressure guage or check it manually, its just making me mad my stupid tach already doesnt work either i hate ford tachs.
Old November 29th, 2011, 02:24 PM   #12
Tang Stang's Avatar
The surging idle is likely due to the tune, especially if you're running the stock tune with larger injectors/different MAF.
Definitely install a real oil pressure gauge, even if just temporarily. You're not receiving any useful information whatsoever from the factory gauge.
Old November 29th, 2011, 02:26 PM   #13
1989Gt.'s Avatar
1989 Mustang GT
Yeah i know it sucks ok im gonna hook it up to a manual pressure reader for the time being,
And i didnt change injectors or maf so i doubt thats the problem
Old November 29th, 2011, 02:41 PM   #14
Tang Stang's Avatar
Are you running your stock 2V injectors and MAF then? Or the ones that came on the 4V?
Old November 29th, 2011, 02:43 PM   #15
1989Gt.'s Avatar
1989 Mustang GT
The ones that came with my 2v. Im not 100% sure im making over 280whp IT honestly runs fine. When i get on it. I did pop a lean code bank 2 when i first started it but i turned it off and it hasnt came back up yet so im just waiting.
Old November 29th, 2011, 02:55 PM   #16
1989Gt.'s Avatar
1989 Mustang GT
Is a mechanical or electrical aftermarket gauge better?
Old November 29th, 2011, 03:00 PM   #17
Tang Stang's Avatar
I prefer electrical as it's a cleaner install as opposed to routing the capillary tubing for a mechanical, but that is entirely your choice.
Old November 29th, 2011, 03:08 PM   #18
1989Gt.'s Avatar
1989 Mustang GT
will a sunpro one suffice? for awhile till i can get a autometer?
Old November 29th, 2011, 03:22 PM   #19
1989Gt.'s Avatar
1989 Mustang GT
http://www.youtube.com/user/xtreme34.../1/lp6CFXTfw1E
Old November 29th, 2011, 03:24 PM   #20
1989Gt.'s Avatar
1989 Mustang GT
Threads Similar to: oil pressure at. idle
weird idle after pressure wash Chris951 5.0 Mustangs 22 August 25th, 2009 02:05 PM
Idle Vacuum and fuel pressure NDblackstang 2005 - 2010 17 September 1st, 2008 01:04 PM
(04 Mach I) Normal Warm Idle oil pressure? NewSchool 4V / SVT 1 July 14th, 2008 07:34 PM
oil pressure to low at idle?? jasons_98gt 96-98 9 July 1st, 2008 11:03 PM
