whats a safe opperating temp...i think im running COLD - Page 2
Old December 5th, 2011, 11:54 AM   #21
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
ya why get a tune and not inlcude a 93 oct tune..its a bigg help and its so easy to add..
Old December 5th, 2011, 12:40 PM   #22
EcoFriendly_lol's Avatar
'96 T-bird, '85 MustangGT
15.17 @ 90.7
EcoFriendly_lol is on a distinguished road
Originally Posted by 1996 GT View Post
You're missing the point. You car is tuned to run 87 octane, do you know the differences between fuel grade? Running TR6's is pointless right now being N/A and virtually stock. Your thermostat wont make a difference on engine ping. Are you sure your not just hearing an exhaust leak and thinking its a ping? It's common. The only thing you will benefit from a tune if you're still staying on 87 octane is your shift points, as towards actual power increases there will not be a huge jump. That manifold will probably bring you up 10-15 horse. Even with a full pi engine you still should be running TR55GP's. Your compression isnt high enough, and you dont go colder unless your F/I and even then you should be gaping a colder copper plug with a 0.034.
Yes, I do know the differences between fuel grades. Colder thermostat eliminated my pinging by allowing the coolant temps to stay at a colder temp as long I was moving. Cause and effect. Pinging comes back lightly when the temps go up over 195ish degrees. I do not have an exhaust leak. I know the difference between the two sounds. The factory tune is relatively conservative and there is power to be had, even if it isn't much. I do plan to stay with 87, until I have the extra money for the additional 93 tune. With a colder engine, by 10 degrees, I can run more ignition timing before spark knock occurs.
Michael M
1985 Mustang GT conv. 600 CFM Holley 4160, equal length headers, true dual exhaust, 3.55:1 8.8'' rear, 10.5" FR clutch.
1996 Thunderbird LX. PI intake, 3.73 TL, tune, j-mod, other goodies. 1/4: 15.421 sec @ 88.27 MPH (with no mods)
Old December 5th, 2011, 02:53 PM   #23
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
Just informing you that you will feel maybe slight better throttle response and thats about it staying on 87. A 195 thermostat wont cause pinging unless its not opening. For the money you're spending on a tuner get gears, an cai, finish the pi swap and smile with that. Timing isnt all about "adding more ignition" thats not the only factor to do with timing. Until you're running a high compression engine you're only changing things that dont need to be changed. Your compression is at 9.0:1 right now, do a full pi SWAP you should be at roughly 10.5:1. A pi engine should be at 10.0:1. Until you hit usually about 11.0:1 then you should be fine with TR55GP's. After all that is done finish full exhaust work THEN get a tune. Until then you're not really freeing anything up with an 87 tune. There isn't much performance to be made with 87. Trust me i run 87 in my car, but in Canada we dont get 93, we get 91 or 94. 94 is about 1.48 a liter over here which is very costly.
Old December 5th, 2011, 03:23 PM   #24
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
damn 5 bucks a gallon.... That atrocious
MM FOBRA CLUB MEMBER #1
Old December 5th, 2011, 04:12 PM   #25
15.17 @ 90.7
I have a pair of PI heads, fully assembled, sitting on my shelf in my garage, I just don't have the funds for the head swap quite yet. I'm getting gears and I already have a CAI system. The only reason I'm doing the PI intake swap is my NPI intake cracked somewhere I can't see. It even has the aluminum coolant cross over. lol As a full time college student, my funds are quite limited right now. So, what's happening this month is about all that will happen for a while. So far, the car has a j-mod in the trans valve body, Steeda under drive pulleys, CAI, cat back exhaust, and an aluminum drive shaft out of a Lincoln Mk VIII. As far as the cooler plugs and thermostat goes, I was just going by what my tuner/ mechanic told me to do based on his professional opinion and experience. I can trust him. Heck, his T-bird is running high 10's in the 1/4 with 660 HP and full weight, through a 4R70W. I don't mean to come off as a jerk, in case I am, but that's what I working off of.
Michael M
Old December 5th, 2011, 07:08 PM   #26
Blackwid0wXR7's Avatar
1995 Mercury Cougar XR-7
15.77@87.23
Blackwid0wXR7 is on a distinguished road
Oh god.... when birds and horses collide.
TCCoA Member and MN-12/FN-10 Expert!
http://www.fquick.com/Blackwid0wxr7
Mods:CAI, TR-3650, RAM HDX Clutch kit, Custom Aluminum Driveshaft, Koni Adj. Gas Shocks, 1.6" Drop Vogtland Springs
Old December 5th, 2011, 07:36 PM   #27
TooFast4theFUZZ
no when cougars and mustangs collide..lol
Old December 6th, 2011, 04:41 AM   #28
1989Gt.'s Avatar
1989 Mustang GT
OMG is that a cougar!
Old December 6th, 2011, 10:55 AM   #29
TooFast4theFUZZ
^ lol
Old December 6th, 2011, 11:00 AM   #30
bigjohnstud4200's Avatar
2000 GT 'vert
bigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura about
Mine runs between 195 and 200 in the heat of Arizona or in the desert cold (25 is usually about the coldest). I have a 192, stock thermo. I would use a handheld and check the actual temp.
"...but don't say my car's topless, say the titties is out"
Nas
Originally Posted by thrashersonmomma09 View Post
( member as in person not as in cock although i do love cock)
Old December 6th, 2011, 02:54 PM   #31
Traction...?
1996 GT's Avatar
LOL ford really got their use out of the 4.6, only half the trucks and cars they made had it.
No i understand, I'm a full time student too. Therefor why my car isnt running 13's yet. Cars are an expensive hobby.
No kidding, its 1.189 a liter today for 87, but it only costs 30$ to fill up the winter beater and that lasts a week.
Threads Similar to: whats a safe opperating temp...i think im running COLD
Temp position when cold? 94FiveOVurt 5.0 Mustangs 3 June 18th, 2011 09:58 AM
Nitrous, Whats Needed To Run It Safe? CandyredGT 2005 - 2010 61 August 18th, 2010 12:49 PM
Running 110 Racing Gas ...Safe? Josh2J 99-04 13 June 28th, 2010 02:59 PM
Whats a safe rpm range for a 347? dr.gonzo! 5.0 Mustangs 9 July 25th, 2008 03:15 AM
is it safe to intall a new battery while the car is running? 91cobra5.0 5.0 Mustangs 31 March 28th, 2008 11:54 PM
