whats a safe opperating temp...i think im running COLD
Old December 1st, 2011, 10:36 PM   #1
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
i have a 180 degree thermostat and a dyno tune with a ram for my intake for coldair and a shortram intake, ported typhoon manifold, exhaust with no cat and those should be the only mods that would effect the temp id think..any ways..one pic is of it at typical highway speeds with the heater on medium at 65mph and 40 degree weather, the other is city driving after like 20 miles with no heater on and a few hard revs after i stopped to take the pic..am i running to cold? and if so what issues could this cause..
Old December 1st, 2011, 10:48 PM   #2
1998 Mustang GT
MustGT98allday will become famous soon enough
i wouldnt trust the gauge. our cars (4.6's) normal operating temp is 220 which is when the fan kicks on. the only way to tell would be to hook it up to a scan tool and watch the temp on that. i never trust a gauge
pi swapped and dropped sn95
Old December 1st, 2011, 10:49 PM   #3
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
My gauge used to sit at the start of the normal range.
your fine
if the gauge registers your like 160-170
410rwhp 520rwtq @ 12.9 psi
Old December 1st, 2011, 11:57 PM   #4
TooFast4theFUZZ
my guage in teh car is pretty accuate..i can change around mods and get diff readings..this is just the coolest its ran and i didnt want to stay in what is it called?? start up mode???
Old December 2nd, 2011, 02:54 AM   #5
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
Put a thermoscope on it
MM FOBRA CLUB MEMBER #1
Old December 2nd, 2011, 04:04 AM   #6
NOR*CAL's FINEST
3valveStallion's Avatar
2006 Mustang GT
Established in the back of a Boss 429 circa 1988
3valveStallion will become famous soon enough
no such thing as too cold. heat robs power and efficiency, if theres combustion, its hot enough. ive never heard of an engine adversely affected by running too cold
(BBK TB)(JLT CAI)(BMR A-Arms)(J&M LCAs)(Pypes C-back)(BAMA93)(PS LTs)(PS O/R H)(Steeda CMDPs)(Prothane Bullet Mnts)
Old December 2nd, 2011, 05:23 AM   #7
1989Gt.'s Avatar
1989 Mustang GT
in a sense but a under cooled engine will wear out the cylinders + rings faster then a properly warmed block....
Old December 2nd, 2011, 06:23 AM   #8
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
If the gauge registers something your already out of the "cold start" mode
Old December 2nd, 2011, 08:38 AM   #9
BLUE91GT's Avatar
BLUE91GT is on a distinguished road
You have to remember too that our cars are set for the fans to come at 220 If I remember correctly. If you change the thermo to a 180 you need to adjust the turn on points of the fans to match. I have run stock and 180 and the car seemed to run better at 195 and my heater did a better job on the few shitty days we have here in nor cal each year. Just my
02 GT- TF TB/ upper, flows, steeda triax, steeda UDP, BBK CAI, H&R SS springs, Steeda SFC, Poly bushings, AGX shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Rear control arm kit.
Old December 2nd, 2011, 09:01 AM   #10
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
If you're concerned about it, install a real gauge. Or use a scan tool, handheld tuner, etc.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old December 2nd, 2011, 10:03 AM   #11
TooFast4theFUZZ
thanks guys....
Old December 2nd, 2011, 05:03 PM   #12
96-GT_Josh is on a distinguished road
I wouldn't trust any of the stock gauges at all. My engine temp would say I was almost overheating 90% of the time so I got an aftermarket gauge. Car warms up to 190 for a while then goes to 220 then fans kick on then goes back to 190.
With both gauges in the car I noticed the stock one has a range from about 145ish at the C line to 220 at 3/4 (at least in my car) and with that close of a range the needle will move a lot with the fan/thermo cycle. As compared to my aftermarket gauge with a 200* range the needle only moves 1/4".
Old December 2nd, 2011, 10:59 PM   #13
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
My car runs like that on the highway constantly, then kicks right up slightly past the middle in the city or if im getting on the pedal. I wouldn't be to concerned, or at least im not.
Old December 3rd, 2011, 12:06 AM   #14
Ok just went for a drive. My gauge reads close to c when the aftermarket one read 192. Garbage stocky.
Old December 3rd, 2011, 02:11 AM   #15
Jhoward93's Avatar
1997 Mustang GT
Jhoward93 is on a distinguished road
I have an aftermarket gauge an mine runs 180.
A few racing videos.
http://www.youtube.com/user/MrJhoward93?feature=guide
Old December 4th, 2011, 08:07 AM   #16
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
Yeah i found my car to run better and harder at stock temp set. i saw no reason to go lower in thermostats like before. it generally runs fine.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old December 4th, 2011, 10:38 AM   #17
EcoFriendly_lol's Avatar
'96 T-bird, '85 MustangGT
15.17 @ 90.7
EcoFriendly_lol is on a distinguished road
You can go with a lower thermostat, but I'd say no lower than 180 degrees. The benefits of doing so, in addition to colder spark plugs, is to be able to run more ignition timing for any given grade of fuel you use. However, if you never turn down the fan temps, you won't be able to make full use of that mod.
I'm running a 180 degree t-stat and NGK TR6 spark plugs in my T-bird right now. The car is getting a tune later this month to make use of these changes...in addition to the PI intake manifold and to change the shift points for the 3.73's. My temperature gauge is doing the same things as OP's.
Michael M
1985 Mustang GT conv. 600 CFM Holley 4160, equal length headers, true dual exhaust, 3.55:1 8.8'' rear, 10.5" FR clutch.
1996 Thunderbird LX. PI intake, 3.73 TL, tune, j-mod, other goodies. 1/4: 15.421 sec @ 88.27 MPH (with no mods)
Old December 4th, 2011, 08:34 PM   #18
Traction...?
1996 GT's Avatar
^ Why would you run a TR6 on a mostly stock engine? You're running copper plugs and a 6 is slightly to cold. IMO you should be running a TR55GP or at least a TR55 in a virtually stock engine.
Old December 4th, 2011, 11:11 PM   #19
15.17 @ 90.7
Why not? lol TR55 is the stock heat range. TR6 is one heat range cooler. The car is going for a tune here shortly after I install the PI intake manifold and have 3.73's installed. I've been having some pinging on regular fuel. I was told by my mechanic friend last week to run TR6's and a 180 degree thermostat. He knows what he's talking about when it comes to mod motors. All the vacuum hoses have been replaced, all O2's have been replaced.
Michael M
Old December 5th, 2011, 11:41 AM   #20
Traction...?
1996 GT's Avatar
You're missing the point. You car is tuned to run 87 octane, do you know the differences between fuel grade? Running TR6's is pointless right now being N/A and virtually stock. Your thermostat wont make a difference on engine ping. Are you sure your not just hearing an exhaust leak and thinking its a ping? It's common. The only thing you will benefit from a tune if you're still staying on 87 octane is your shift points, as towards actual power increases there will not be a huge jump. That manifold will probably bring you up 10-15 horse. Even with a full pi engine you still should be running TR55GP's. Your compression isnt high enough, and you dont go colder unless your F/I and even then you should be gaping a colder copper plug with a 0.034.
Threads Similar to: whats a safe opperating temp...i think im running COLD
Temp position when cold? 94FiveOVurt 5.0 Mustangs 3 June 18th, 2011 09:58 AM
Nitrous, Whats Needed To Run It Safe? CandyredGT 2005 - 2010 61 August 18th, 2010 12:49 PM
Running 110 Racing Gas ...Safe? Josh2J 99-04 13 June 28th, 2010 02:59 PM
Whats a safe rpm range for a 347? dr.gonzo! 5.0 Mustangs 9 July 25th, 2008 03:15 AM
is it safe to intall a new battery while the car is running? 91cobra5.0 5.0 Mustangs 31 March 28th, 2008 11:54 PM
