Fluid on my tranny...??? not good... '96 Cobra
I was under my car last night fixing an exhaust leak when i notice fulid on the bottom of my tranny. It appears to kinda red in color. And seems to be coming from around the middle of my trans. How can i check my fluid level in the trans? Or do i just have to drain it and refill it?
Another thing. My car seems to use oil. Don't know where it goin??? the car doesn't smoke. Could my rear seal be leaking? Would this be the fluid on my trans?
![]() 96' "Slowbra" B&M Shifter JLT RAI No Cats Flowmasters Wheel Spacers KYB struts Eibach Springs BF Goodwrich G-Force in 4 corners. |
11.21@123 -150 shot
![]() iTrader: 1 reviews
The red fluid is tranny fluid. You may be leaking it from around the shifter or input shaft.
Engine oil, need more info. You say it is not smoking but is there a spot on the floor after you park it? Could be blow by if it is a high mileage vehicle. How much oil is it using per 1000 miles?
1998 SVT Mustang Cobra
i have a 98 cobra with 70,000 miles on it and i also us oil without the car smoking. I have never seen an oil spot on the ground from my car, and the oil usage isn't too bad, so i just don't mind it
Kennebell 2.1L Twin Screw soon tooooo cooome! ![]() __________________^__________________ IT'S WATCHING YOU VETTE BOY |
yeah in my 2v same on the oil..dont see it on the ground and no smoke...its chris angel doing it to us guys!!!!!!
She has 97,000 miles logged on er'. There doesn't appear to be any oil on the ground. Where is it goin???
The Hammer
Millenium Falcon
I've got the same thing.....i go through about a quart every 2000. I've only had the car for 4500 and changed the oil once, but never new the level from the day i got it. 66.5 on the clock
I just put a new thread up about my car smoking white and slight oil consumption. I've had mine for about 1,500 and used some too. Are you guys going WOT a lot or is that quart your running through daily driving like a civil human?
Threads Similar to: Fluid on my tranny...??? not good... '96 Cobra
| Tranny Fluid | armymike63b | 99-04 | 7 | November 12th, 2007 10:27 PM |
| tranny fluid | fsttang96 | 96-98 | 7 | October 27th, 2007 10:31 PM |
| tranny fluid | 96gtponyred | 96-98 | 4 | August 8th, 2007 04:49 PM |
| What Fluid do you use in your T5 Tranny? | noyz25 | 5.0 Mustangs | 6 | August 6th, 2007 04:25 AM |
| tranny fluid | terribleonexx88 | 5.0 Mustangs | 20 | November 24th, 2006 05:41 PM |
