96 gt vert
![]() iTrader: 1 reviews
blue smoke
any time i rev my eng when its cold i get blue smoke rember i came from driveing a mazda rx7 all my life lol an blue smoke means oil ring are goin lol i know thats not wha it means can some one help me.
Just a few moddes 2 in drop ksport an MAC cat back pi intake an siting on 17x11
MM sticker peddler
slowmatic
![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Blue smoke is usually burning oil.
Visit this thread, more stickers possible coming soon! http://www.moddedmustangs.com/forums/clubhouse/263411-gauging-interest-more-new-mm-sticker.html
1997 Pacific Green Cobra
14.80 No traction
probaly valve stem seals. Good time to just go and do a PI head swap while at it . I have that now, but im building a whole new motor soon im not sweating it and its not that serious .
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
96 gt vert
I was thinkin piston rings
1998 mustang gt
to be announced
its burning oil this is typical for a mustang motors, if its a 4.6 then that's what it is as long as its not bad i wouldn't worry bout it to much but yes most def a good time to switch to a pi swap. The other question not asked is do u have a cat less h pipe or x pipe some of that smoke could be from not having cats mine does this now and its not using any oil and only has 40 thousand on the motor does it smell rich ?
98 gt mustang
1998 Mustang GT
14.15@105.5
Sounds like valve stem seals. If it was piston rings the smoke would be more and more as you rev and drive the car. It seems like for you it is only when you first start it in the morning, so definitely valve stem seals. I had the same issue. I took it as an opportunity for a port and polish and PI intake swap xD
1998 Mustang GT
![]() iTrader: 2 reviews
blue smoke= oil
black smoke= gas white smoke=condensation/antifreeze ALWAYS
pi swapped and dropped sn95 |
96 gt vert
Thxs guys how long would u say it takes to do a pi swap
1970 Mercury Cougar.
Depends on your mechanical ability and if there are complications. Me doing it, maybe 12 hours with the engine in the car, 10 pulling the engine. Way more if I hit complications such as stubborn bolts or something.
1970 Cougar. |
96 gt vert
ok thats not to bad well its time for me to start buying parts.
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
theres always something that doesnt go as planned,and its best if you have a bud helping you..
Traction...?
1996 GT/ 2008 GT Vert
I'm on the same boat for a PI swap, my engine is just about ready to be pulled now, need to finish un bolting the tranny mount, engine mounts and drive shaft bolts and should be ready to go.
96 gt vert
true true an when its your first time i can see an hear me now lol im going to the yard an look in for a vic on fri what all can i use be sides the heads an intake
Threads Similar to: blue smoke
| Blue smoke from exaust!!!! | napwrd2vgt03 | 99-04 | 6 | January 1st, 2011 05:31 PM |
| Need Help Blowing Blue Smoke!! | built4ford | 2005 - 2010 | 18 | March 21st, 2010 07:37 PM |
| Blue Smoke? | 40thmustanggt | 99-04 | 38 | April 17th, 2008 03:24 PM |
| blue smoke | 96gtponyred | 96-98 | 22 | September 6th, 2007 10:17 AM |
| Why The Blue Smoke From My 06 GT | 216-06-GT | 2005 - 2010 | 20 | September 17th, 2006 03:14 AM |
