buiding a cobra
Old December 11th, 2011, 12:07 PM   #1
1978 mustang
mattzhat is on a distinguished road
buiding a cobra
I have in my possesion a 96 aluminum cobra short block. My goal is to put it in a mustang, turn it into a 347, and turbo it. Im wanting to get about 8.5 compression or lower. but the main thing for me is doing all the fule injected and computer stuff as I have only made carbourated motors. So i need a list of stuff to buy to get the motor fule injected (I would prefere cobra parts) and to bore it to a 347 with low enough compression to run decent boost. I dont know if this will be relavant but it will be in a 69 mustang will a 5 speed. All the info, help, and tips will be much epriciated as I dont want to go the carborated route.
Old December 12th, 2011, 12:45 PM   #2
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
#1. If you were to go the "Big Bore" route (which involves resleeving the block with 3.700" sleeves) and run a 3.800" stroke crank, you would end up with 327 CID. I'm not sure where you're getting the idea that you'll be able to bore/stroke it to 347 CID.
#2. I would recommend AT LEAST 9:1 compression, preferably closer to 9.5:1-10:1 with a turbocharger. A 8.5:1 CR is unnecessarily low, and will result in a real pooch when out of boost.
#3. As far as a "list of stuff to buy to get the motor fuel injected" goes, it sounds like you need to start with getting the heads, cams, valvecovers, upper/lower intake, fuel rail, fuel injectors, wiring harness, throttle body, IAC, etc.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old December 12th, 2011, 09:09 PM   #3
1978 mustang
Right on. and my bad about the cobra 347 thing Im not a big ford guy so i automatically assume every thing is a 302. Will i have to get a different computer and what size turbo would be best. and how much horse do you think this block can take
Old December 12th, 2011, 11:28 PM   #4
Speedstang302's Avatar
13.64@101mph
block isnt the weak link its the rods and pistons...and automatically assumed? thats like me buying a chevy and saying everythings a 5.7L? i think you need to evalute what you want as a final goal and how much money you have to spend cuz a turbo setup on a mod motor is far from cheap or if cheap isnt going to end up cheap...most people run single 61's, 67's and 70's on the street...and you wont need a different computer just need the factory one tuned
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old December 13th, 2011, 09:16 AM   #5
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Unlike the 5.0 blocks, with mod motors the first thing to go is the conrods. Conrods will usually start punching windows in your block somewhere between 400-500rwhp.
The good news is that if you have a 96 Cobra shortblock you have a good starting point. It's a lightweight Teksid block that can take upwards of 800hp. If you're not looking to break 500hp you don't need to touch it. If you do want more, get new conrods/pistons, keep the CR in the 9.1-9.5 range. You already have a forged crank.
For the rest of the engine you can scoop up as many 96-98 Cobra engine parts as you can to finish it out.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Threads Similar to: buiding a cobra
which engine for 1500 rwhp 2003 cobra 1999 cobra or 2000 gt gtjason New Members Introductions 14 February 19th, 2012 09:19 PM
Buiding a 351 for future s/c. A couple of questions DJKING 5.0 Mustangs 20 April 12th, 2007 09:48 AM
