10w-40 Or 20w-40
Old December 11th, 2011, 10:12 PM   #1
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
10w-40 Or 20w-40
Was wondering if this would be ok to run in my pony to see if the oil pressure picks up.
MM FOBRA CLUB MEMBER #1
Old December 11th, 2011, 11:01 PM   #2
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
I have 10w-40 in the '08 GT, hasnt really been driven with it in due to the winter but sat and idled perfect for 10 minutes.
Old December 11th, 2011, 11:21 PM   #3
1989Gt.'s Avatar
1989 Mustang GT
ok I figured it would be ok its not much thicker then 5w-30 that alot of people use... But i just wasnt sure.
Old December 11th, 2011, 11:24 PM   #4
Traction...?
1996 GT's Avatar
I have a guy i work with running 15w-50 in his '97 eclipse GST. Says the car loves it.
Old December 11th, 2011, 11:30 PM   #5
1989Gt.'s Avatar
1989 Mustang GT
Well i just did a oil pressure test today and it just seems a little low. to me not too low but a little low
Old December 11th, 2011, 11:32 PM   #6
Traction...?
1996 GT's Avatar
Mines super lower right now, but ill be putting 10w-40 in it most likely also, if that doesnt bring it up time for a new oil pump or sending unit.
Old December 11th, 2011, 11:36 PM   #7
1989Gt.'s Avatar
1989 Mustang GT
Whats yours at could you give me your specs.
Mine was 10-11 psi at 800 rpm
7-9 at 650 rpm
1500rpm 18-20psi
3000rpm was 30-35
Old December 11th, 2011, 11:42 PM   #8
Traction...?
1996 GT's Avatar
I'm on a stock gauge, i need a real one put in this winter. It sat at the "O" on NORMAL.
Old December 11th, 2011, 11:46 PM   #9
1989Gt.'s Avatar
1989 Mustang GT
Woah woah woah you know that the stock gauge is just a switch right... You should be pretty worried because
The stock gauge reads 6 psi if its lower then that then your gonna have some problems.
Old December 11th, 2011, 11:48 PM   #10
1989Gt.'s Avatar
1989 Mustang GT
its prolly your sending unit.
Old December 12th, 2011, 12:56 PM   #11
Traction...?
1996 GT's Avatar
Yeah ill be doing a sending unit this winter, and a proper gauge. I think i was loosing a little bit of pressure do to a leaky valve cover grommet, but thats no problem now.
Old December 12th, 2011, 08:34 PM   #12
blkfordsedan's Avatar
blkfordsedan will become famous soon enoughblkfordsedan will become famous soon enough
The valve cover has nothing to do with oil pressure. The oil pressure is the internal oil passages that feed the bearings. I would recommend replacing the sending unit or installing a real pressure gauge. Both are very easy to do on these cars. Running an oil with higher cold temp/cold start viscosity will only accelerate engine wear. If you really need a thicker oil due to high miles and increased bearing wear, I would recommend a 5W-40.
-Brian
2004 GT
TR3650, MAC Straight Shot CAI, FRPP 70mm, TFS plenum, catted X-pipe, Pypes Violator polished
304SS cat-back, custom tuned by AM/Bama......
4.10's - coming soon!
Old December 12th, 2011, 09:10 PM   #13
1989Gt.'s Avatar
1989 Mustang GT
It's a fresh engine rebuild
Old December 12th, 2011, 09:38 PM   #14
Traction...?
1996 GT's Avatar
Yeah like i said i will be getting a sending unit, im starting the engine pull tomorrow, ill also be adding a gauge in also.
Old December 12th, 2011, 10:12 PM   #15
1998 Mustang GT
MustGT98allday will become famous soon enough
instead of using thicker oil i would find the real problem of the oil pressure. dont just use wrong oil cuz you want to boost up the pressure. change the gauge and sending unit first and then go from there
pi swapped and dropped sn95
Old December 13th, 2011, 12:19 AM   #16
1989Gt.'s Avatar
1989 Mustang GT
For the 3rd time I have been using a manual oil pressure gauge
Old December 13th, 2011, 09:35 AM   #17
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
In another thread you said that you're running bearing tolerances that are on the "tight" end of specs. If that's the case, I really wouldn't recommend increasing the oil viscosity.
Agreed. Don't mask the real issue. If you assembled the engine with tolerances conducive to 5W-30, don't stick 20W-40 oil in it.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old December 13th, 2011, 06:18 PM   #18
1989Gt.'s Avatar
1989 Mustang GT
yeah I just asked my fathers friend what the tolerances were.
Old December 13th, 2011, 06:41 PM   #19
1989Gt.'s Avatar
1989 Mustang GT
So the tolerances were between .0015 and .002 he said all of them were that close.
Old December 14th, 2011, 12:28 AM   #20
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
neither....dont even consider it . seriously tho. 10w is not good startup protection at all. what is the PSI ... 9psi is minimal at idle.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
