Oil coming out of my air filter help! - Page 2
Old December 13th, 2011, 10:59 PM   #21
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
Ask 97S281, he has them, im sure if you show him some pictures he will be able to tell you.
Old December 14th, 2011, 12:32 PM   #22
Borrelli49's Avatar
Borrelli49 is on a distinguished road
I think for now im just going to stay on the cheaper side of things and pick up a used one but i need to know does anyone know if the PI heads will work with this supercharger?
Old December 14th, 2011, 07:43 PM   #23
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Check the casting numbers on the side of the head. They should look like this:
You should be able to read the drivers side from under the car. I would not swap out for pi heads if you actually have the svo's on there. You will loose alot of power doing that.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old December 14th, 2011, 07:48 PM   #24
Borrelli49's Avatar
ok good to know I will check as soon as i get a chance, thank you
Old December 14th, 2011, 08:03 PM   #25
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
There is some good info on the svo heads in Sean Hyland's " How to build max performance 4.6 liter ford engines". The section on svo heads is on page 37 and the flow chart for the heads is on page 51 if you want to check it out next time your at the parts store.
MODS IN GARAGE
NCMM ORIGINAL
Old December 14th, 2011, 08:14 PM   #26
Borrelli49's Avatar
Ok looks like non PI heads, and not SVO heads.....
Old December 14th, 2011, 08:24 PM   #27
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Well, that sucks.
MODS IN GARAGE
NCMM ORIGINAL
Old December 14th, 2011, 08:27 PM   #28
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
http://www.moddedmustangs.com/forums...-shipping.html
I am making 432crank /375 rear wheel with the blower, stage 2 cams and the svo heads. That is on only 5lbs of boost. I haven't swapped out for a 9lb pulley yet. I imagine I will be considrably higher once i do that but I want to install a snow performance meth kit first.
MODS IN GARAGE
NCMM ORIGINAL
Old December 14th, 2011, 08:31 PM   #29
Borrelli49's Avatar
wow thats alot of power. the guy gave me a dyno sheet where it only made 315hp
Old December 14th, 2011, 08:36 PM   #30
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
That's kinda high unless you have gears, exhaust, cams and a real good tune. Most guys running the blower on a stock setup see arounrd 280-295.
MODS IN GARAGE
NCMM ORIGINAL
Old December 14th, 2011, 08:39 PM   #31
Borrelli49's Avatar
it has 4.10s no cats with 40 series and it was tuned by a pretty good performance shop. but like i said the heads dont look like they have ever been removed and they look stock i couldnt find any markings on them
Old December 14th, 2011, 08:44 PM   #32
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Well, they should be maked on the exhaust side. The other way to tell is to remove the intake and look at the intake port. It should be a teardrop shape like this:
MODS IN GARAGE
NCMM ORIGINAL
Old December 16th, 2011, 04:17 PM   #33
Borrelli49's Avatar
Just an update.....
Purchased a Short Block
All the Gaskets and ARP Head Bolts
Stage 2 Clutch Kit
Cold air intake
Spark Plugs
Fuel Filter
BBK Shorty Headers
and a much needed new shift knob
Should be together and running by next friday.
After i get all of that done it will be time to get it tuned and dyno'd!!!
Old December 16th, 2011, 04:23 PM   #34
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
What did you go with in regards to the shortblock?
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old December 16th, 2011, 04:37 PM   #35
Borrelli49's Avatar
Forged Rods and pistons
Old December 16th, 2011, 04:38 PM   #36
Borrelli49's Avatar
just a short block i found on ebay for like $2400
Old December 24th, 2011, 10:16 AM   #37
Borrelli49's Avatar
Well I just picked my car up from the shop last night. I must say he did an awesome job he pulled the motor Wednesday morning and had it running last night at about 6:30. The clutch has a little chatter to it but i guess it just needs to be broken in some more. overall it has twice the power it had before. now just time for the crappy break in period.
Threads Similar to: Oil coming out of my air filter help!
Fuel Filter or Running Lean? Thinking filter 20TENGT615 2005 - 2010 36 December 15th, 2011 10:23 AM
So can I use my KN filter on stock intake with EBAY's CAI's? Sell CAI without filter? 4U2C V6 Mustangs 25 July 14th, 2011 01:34 AM
Short air filter vs normal air filter Steelsoldi3r 96-98 18 January 24th, 2010 08:36 PM
I was changing the air filter for a K&N filter and I noticed- Huxley 99-04 14 April 2nd, 2009 05:04 PM
Cone filter vs. box filter lilgreenstang 2.3 Mustangs 3 April 16th, 2008 01:06 PM
