Oil coming out of my air filter help!
Old December 12th, 2011, 11:09 AM   #1
Borrelli49's Avatar
Borrelli49 is on a distinguished road
I just purchased this 1996 GT with a 4.6 says the the guy i got it from it has an svo head,intake, and an Eaton supercharger. The supercharger sits below the intake ive never seen one like this before. I thought at first it was a bad PCV valve and it helped but im still noticing some oil coming from the air filter the first time it happened 2 quarts dripped out. and it only drips out after i hit full boost and shut the car off? any help would be great!
Old December 12th, 2011, 12:21 PM   #2
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Post pics of your setup, specifically of the PCV arrangement (both sides). It sounds like it may not be routed correctly.
I hope that "2 quarts" was an exaggeration!
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old December 12th, 2011, 12:49 PM   #3
Borrelli49's Avatar
I also forgot to mention i unpluged some on the vaccum lines t-ed off of it and it seemed to help and i havnt noticed any oil leaking back out at this point but im at work now and will post pictures later. and i was not exaggerating on the 2 quarts. that only happened once tho, the second time about 1/4 quart came out
Old December 12th, 2011, 01:38 PM   #4
Tang Stang's Avatar
It sounds like that is where the problem lies (the PCV line routing).
Old December 12th, 2011, 01:54 PM   #5
Borrelli49's Avatar
but the pcv routing has not been messed with its still the stock set up
Old December 12th, 2011, 01:56 PM   #6
Tang Stang's Avatar
Which is an issue, since you're running the SVO supercharger.
Old December 12th, 2011, 02:13 PM   #7
Borrelli49's Avatar
The only thing is I cant find any information on the SVO set up. talked to some techs at the ford dealer today and they are all thinking i might have a cracked piston but i figured if i did i would be burning oil and it would just be obvious. does anyone have some info on the SVO PCV setup??? Im going to run some compression testing on it later when i get off work
Old December 12th, 2011, 03:03 PM   #8
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I have the svo heads and blower. Here is a pic of where mine goes.
It comes out of the pcv valve and makes a very short jouney to the lower port on the back of the blower elbow you see in the pick.
I have never had any problems with oil in my air filter from it.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old December 12th, 2011, 03:05 PM   #9
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
FYI, If you are runing the svo blower you are technically NOT running the svo intake as well. The svo intake looks like the bullitt intake. The setup is not stock. It was made available by Ford Motorsport SVO in 1998.
This is the svo intake:
I have one just in case I decide to go Turbo in a few years.
Welcome to the forums. Glad we could answer some of your questions. Feel free to PM ( private Message) me if you need any other pics of my setup to help you get yours sorted out.
MODS IN GARAGE
NCMM ORIGINAL
Old December 12th, 2011, 07:30 PM   #10
Borrelli49's Avatar
ok i ran a compression check on it and the entire right side bank all ran at about 40 PSI the left side bank ran at about 160-180. We ran a wet check on it and the heads seem to be ok looks like Manley pistons and connecting rods now??
Old December 12th, 2011, 09:12 PM   #11
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
check for oil in coolant? headgasket maby or ring seals? ive always loved that svo charger..
Old December 13th, 2011, 09:36 AM   #12
Tang Stang's Avatar
Sounds like you have much larger problems than just a PCV issue then.
Old December 13th, 2011, 12:26 PM   #13
Borrelli49's Avatar
Now my question is what to do. i have a $3500 window and ill be doing the work. ive been looking at short blocks and i can get a forged short block for about 2800.
Old December 13th, 2011, 09:09 PM   #14
TooFast4theFUZZ
^ Fk it must be nice...hahah i feel happy when i get to spend 200 on my car..but anyways for that cash id get a 32V,cobra intake it and cam the shit out of it and go from there..
Old December 13th, 2011, 10:05 PM   #15
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
^ LMAO, this is the truth. I spent 220$ the other week and was like awwwhhhhh yeahhhh.
Old December 13th, 2011, 10:21 PM   #16
Borrelli49's Avatar
But if i go that route my blower would not fit i know that blower does not produce alot of power but i have it so why not use it. I think im just going to go with a Forged Bored and Stroked short block that way what every i throw at it down the road my bottom end can take it
Old December 13th, 2011, 10:27 PM   #17
Traction...?
1996 GT's Avatar
Forged short block + forged h-beam rods + forged crank (if plan on seeing past 600hp) + stage two blower cams is the route id take imo.
Old December 13th, 2011, 10:28 PM   #18
Borrelli49's Avatar
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Old December 13th, 2011, 10:34 PM   #19
Traction...?
1996 GT's Avatar
I'm not going to lie, if i could afford it with no troubles, id be all over that in a second. What heads and cams do you plan on using?
Old December 13th, 2011, 10:42 PM   #20
Borrelli49's Avatar
Well for now The same ones i have, according to the guy i got it from "it has SVO heads" but if thats true im not sure
Threads Similar to: Oil coming out of my air filter help!
Fuel Filter or Running Lean? Thinking filter 20TENGT615 2005 - 2010 36 December 15th, 2011 10:23 AM
So can I use my KN filter on stock intake with EBAY's CAI's? Sell CAI without filter? 4U2C V6 Mustangs 25 July 14th, 2011 01:34 AM
Short air filter vs normal air filter Steelsoldi3r 96-98 18 January 24th, 2010 08:36 PM
I was changing the air filter for a K&N filter and I noticed- Huxley 99-04 14 April 2nd, 2009 05:04 PM
Cone filter vs. box filter lilgreenstang 2.3 Mustangs 3 April 16th, 2008 01:06 PM
